hi guys i'm looking this forum around one year at least but it's first time i would talk... (authism??? whatever...)
i had this very rare issue on my Wee 2014, it's filtering for this this side (img. attached) it's a little oil filtration but it's something rare...
any sugestions?
pd: i'm a Chilean who likes building motorcycle (for the moment only vstroms) accesories, this week i make a center stand powder coated (by myself!) and i'm going to make the panniers too!
Hi Kako,
I think by "filtration" you mean "leaking".
Do a Google search of the site for "upper engine mount leaking".
:O thanks mate!
i'm a little bit confused with the exactly words (i'm a spanish guy) so i try learn every day (actually i'm looking "bolt upper support engine filtration" LOL)
No need to apologise over your English - it's a lot better than my Spanish! >:)
i try to put my best effort :hurray:
i saw it the other guys with the same problems but nobody could says where's the leaking point exactly... if i remove the bolt and reverse it could be shut off the leak? :confused:
There should be RTV between the case 1/2 sealing that area. If it's not tight or shifted it may leak.
I'd say try and tighten the spanner bolt and nut, motion pro has a tool you can use. May smash the case 1/2 together better and stop the leak.
Part #7
41923-16G00 BOLT, ADJUSTER CENTER $21.50 $17.20
Part #7
i'm gonna do it this weekend... its very rare because if isn't tight the engine may be leak from another sites... no?
