1 - 13 of 13 Posts
What's with online sites
Am I stupid well yes but regarding oil filters
It seems almost impossible to find the oil filters
I can order ANY obscure part but oil filters are hard
Are you looking at Suzuki sites using the old part number? I don't see a problem finding a proper filter otherwise.
oil filters
AMSOil SMF 109
Baldwin B7419
Bike Master 314-0025
Champion PH7016
Cycle Power 314-1919
Emgo 10-55662
Emgo 10-55660
Fram PH6018
Hi-Flo HF138 <-- Recommended
J.C.Whitney ZX063166P
K&N 138 <-- Recommended
NAPA Gold 1359 (at UAP/NAPA) <-- Recommended
WIX 51359 (at UAP/NAPA) <-- Recommended
Parts Unlimited
Per-Form J-509
ProPart 01-0029
Purolator ML16818 <-- Recommended
STP SMO-18
Suzuki 16510-03G00-X07 or 16510-07J00 <-- Recommended
VESRAH vsf-3009
Recommended means John Weldon at VSRI cut it apart and liked what he saw. He has not checked all makes.
oil filters
AMSOil SMF 109
Baldwin B7419
Champion PH7016
Emgo 10-55662
Emgo 10-55660
Fram PH6018
Parts Unlimited
Per-Form J-509
ProPart 01-0029
STP SMO-18
VESRAH vsf-3009
Will those fit both K and L models?
My point was it is surprising to me that it isn't easy as in point click to add to an order for oem parts
Yes. Suzuki has been using the same filters for most of their bikes for longer than V-Stroms have been made.
Nothing wrong with using non-oem, a Hi-flo HF-138 or the K&N 138 version with the nut for easy removal is well proven and decent quality.
Suzuki oil filters are not that great, no need to bother with them. Always used HF-138s on my Suzuki bikes for many years. Local dealer sells them, they don't stock Suzuki filters, no one likes them around here. I do use OEM when it matters or there is a quality difference. I don't use Cummins OEM filters on my trucks because I rather run higher end Fleet Guard filters, the OEM which are made by Fleet Guard are of a lower cheaper line. Go figure. Research matters. I cut a Fram oil filter open myself, ain't going to run anymore unless I have no other choice. I pay around $5.50 for a HF-138 in bulk packs, well they do vary. Buy a 10 pack in the winter and SAVE, like that matters much anyway...
If you're already looking at the diagrams to order OEM parts, it's easy as pie -- the oil filter is on the "OIL PUMP" diagram.
Procycle.us has a V-Strom page where they group together common items for quick shopping. They sell Hi-Flo 10 packs, magnetic drain plugs, spark plugs, chain/sprocket kits etc.
1 - 13 of 13 Posts
