There is a void in the center of the water pump shaft. A seal on the motor side for the oil and a second seal on the coolant side for that. The void is where the drain hole is. Your oil seal is failing, but wont contaminate the coolant because of the double seal. To repair it you need both seals and gaskets for that area.
My leak was on the coolant side and went 1500 mile before replacing by just adding coolant when needed.
