1 - 1 of 1 Posts
Vibration and heat can cause the insulation on your bike’s OEM stator to slowly wear out, thus producing less and less power until it’s ultimately useless. And if you’ve even looked at an OEM replacement stator, you know they can be expensive! Rick’s Motorsports Electrics are a high-quality, reasonably priced alternative to the OEM stator that come out of the box and ready to bolt on for most applications. There’s no drilling for mounts and, in most cases, they come with OEM-style plug-ins for easy, direct replacement.
Rick’s Motorsport Electrics stators are available for 02-09 Suzuki DL1000 motorcycles..
These stators are not yet available on our website. For more information, call Mike at 866.931.6644 x 804 to discuss all options available for your particular motorcycle. You can also send a note to FORUM at RIDERSDISCOUNT dot COM with AFTERMARKET MOTORCYCLE STATOR in the subject line and please be sure to include the model and year of your motorcycle so we can get back to you right away.
Rick’s Motorsport Electrics stators are designed to bolt in place of the OEM unit with almost no modification required. For older motorcycles, you may need to re-use the OEM rubber grommet.
OEM-spec connectors are included with most of Rick’s Motorsport Electrics stators.
1 - 1 of 1 Posts
