Cant tell from the pic. Is the case locked in this picture? MIne has to be in the unlocked position to close all the way. Or maybe the lock is not all the way disengaged.
Case is unlocked. I have tried every way I know. Real mystery that I can get the right side case to operate properly but the left side absolutely will not. If the handle does not fold completely flat, the little bar that slides through the slot will not go through to secure case. The slotted mechanism does not go down far enough to engage the little bar.Cant tell from the pic. Is the case locked in this picture? MIne has to be in the unlocked position to close all the way. Or maybe the lock is not all the way disengaged.
No, key only turns in one direction.Is it not perhaps a case of turn in one direction in ordr to open the panner storage area and the turn the key in the other direction to remove the pannier for the pannier rack?
There is plenty of grease on the inside where the sliding rail is so I have not tried spraying silicon on it. You really can't get any good pictures because of where it is inside of case. The handle comes to a dead stop about 1/4 inch of how far it is supposed to go. Pushing any harder could break it loose....or break the.whole mechanism.No, key only turns in one direction.
