OEM Oil filter without exposed nut at tip?
2546 Views 10 Replies 9 Participants Last post by  bikesrus65
Just curious, I picked up an '05 wee and as it is new to me decided to do an oil and filter change. I picked up an OEM filter from my local dealer (p/n 16510-03G00-X07). When I got it out to install it, it did not have the exposed nut at the tip to tighten it, it just looked like a normal oil filter. Should the OEM filters have this exposed nut? Or do you have to specify a different p/n?
The non-OEM filter that was on there previously lacked this nut at the tip so I do not suppose it is any big deal, just curious as the owners manual shows different.
1 - 11 of 11 Posts
Only the K&N replacement oil filter has a nut on the front. The OEM filter uses a special tool.
Discussion Starter · #4 ·
OK, I see what it is is now. When I went back after seeing the tool posted by Greywolf, that is what I was seeing in the grainy picture. It looked like the K&N filter with the exposed nut.
Thanks.
you can also just use a filter wrench.... they sell that at autozone. or be a cheap ass like myself and just skewer the thing with a screw driver and pry on it when it's time to take it off...
The filter wrench that fits the filters on my Corolla happens to work on the V-Strom filter as well... YMMV. I usually use Wix/Napa filters on both.
Discussion Starter · #7 ·
I did pick up a filter wrench for the wee. This was more confusion over what I saw in the maintenance manual. Looked like the K&N filter with the exposed nut but they were just showing it with the tool on top of the filter. Guess my eyes are getting weaker :mrgreen:
In addition, when I did my oil change after the dealers initial 600 mile service, I used a strap wrench. That thing has come in so handy for other stuff also I am glad I bought it. Since I had it I figured I'd try it.
Rick
filter wrench
I had a band type oil filter wrench used to fit the filter for a 350 Chev. It was too big for the Wee filter , ao all I did was take a small length of used radiator hose and slit it down the middle and fit it inside the band. Grips great and now one wrench fits all!
1 - 11 of 11 Posts
