Odometer blank - rest of cluster working
1160 Views 3 Replies 3 Participants Last post by  Franticvike
Hi All,
I've got a firm deal to pick up a nearly new looking 2014. Only issue I could see was that the odometer doesn't provide any reading. Just a series of 00000s. Owner says it has 5600-6200 kms, and from the looks of it that is quite plausible. I pushed the "ADJ" button numerous times and it would run through a few cycles, but none of them provide a reading on the ODO.
I'll try to link a photo of the cluster reading. Any suggestions?
Speedometer Gauge Vehicle Odometer Measuring instrument
See less See more
1 - 4 of 4 Posts
I think it is in Instrument Panel Light Brightness mode.
Rectangle Font Parallel Number Pattern
See less See more
  • Helpful
Reactions: 3
This is correct, it's the panel lighting setting. Look for the second 'trigger' style button to the right of the clutch, that'll cycle through the OD and trip calculators. I use my left index finger to toggle the switch. Hold it down for 3 seconds and it'll also switch between time and temperature. It's there on the right in the pic...
See less See more
Worked perfect, thank you for the quick reply. 7500km on the clock, I think I’m happy with that.
1 - 4 of 4 Posts
