1 - 4 of 4 Posts
My US DL650 is giving me C44 error for faulty oxygen sensor. I see conversations galore in search, most saying the part is expensive and that US dl650s don't have the sensor. Im confused. Mine seems to run just fine, but should this be replaced and not ignored? What is the not so confusing truth?
It does have an O2 sensor. It may feel like it is running normally, but probably is running at a fixed air/fuel ratio without the ECM adjusting the mixture.
There are most likely some less expensive aftermarket sensors available.
Found what is considered a suitable replacement on ebay, one of the GSX ones suggested by others. Easy swap, no C44 error on a short test ride.
People remove the O2 sensors on the GIxxers for racing. Probably lots of them on fleabay. (y)
WR software can disable the O2 sensor code so no C44 errors displayed.
1 - 4 of 4 Posts
