1 - 4 of 4 Posts
I was directed to this page to fill out my profile, im lost, cant find a button for fill out profile?
It is under "User CP". If you are in Classic mode, it is above and on the left. If Full mode, I believe, it is under Tools and then User CP, which would be above center. If Mobile mode, I believe, it is under Menu and then User CP, which would be above and on the right.
If you are still lost, holler.
At the top of the page in full mode there is a drop down menu with TOOLS. Curser that, click on User CP, then when that page loads, on the left side, top of the column you will see 'Edit Profile'. Click there and the rest should fall into place.
Thanks Stalky, I forgot the classic is different from full mode.
1 - 4 of 4 Posts
