Hey guys, so I just did my oil change on the Wee for the first time (meaning I've never done one) and I think I've overfilled it :headbang:. When adding oil initially, I added till at full, started it up for a moment, turned it off and added some more for the filter. Again started it up and off, oil below the LOW indicator so I added some more. I'm guessing I've added close to 3 litres but that's a guess based on how much remains in the 4 litre jug. The bike is on the centre stand.
Also when turning off the engine and the oil fills back up into the window, it appears quite dark considering it's a fresh batch and also almost frothy, ok the frothy part is no more after a few starts and letting it run for a few min but still it seems a little thick to me. Is this normal considering it's not warmed up properly? Incidentally I did empty the oil last night an with the intent of finishing the job then but just couldn't get the filter off with the rubber wench thingy I got. So it sat without oil all night until I could go out and get the other filter wrench. Not sure if this would make it frothy for some reason??
What's the easiest way to drain some oil? Don't mean to make that sound like the dumba$$ question it is but I'm thinking it's going to get really ugly if I try and drain just a little bit and put the plug back in while it's still spewing out. My oil pan is one of those portable ones and obviously is full of the old oil still but I'm thinking maybe it would be easier to just dump everything out and pour it back in except for a bit less.
Any thoughts on either?
