Noise from abs pump
3440 Views 4 Replies 2 Participants Last post by  OzzyAlex
Hi .i was on forum a while back about abs pump noise.thanks for replies but they didnt help .i worded query wrong. There is a crackling / buzzing sound coming from abs pump when bike is turned on but not started.it is probably there all the time but cant hear it over engine .has anyone any ideas.and if my abs fails will my brakes work.
Your brake will still work no matter the problem.
They will be just like old style brakes with no help from the ABS to stop a wheel locking up.
In very simple terms when the ABS system is activated it does not make your brakes work, it stops your brakes working by releasing braking pressure, it then applies that same pressure again, this happens over and over again until either you release brake pressure or the wheel starts rotating again.
Are you 100% sure it is the ABS, there are a number of things that move & make a noise when the ignition is turned on, there is the motor for the exhaust flapper valve and the valve that could make a noise, ABS systems are very sensitive and will normally show the light when a problem occurs.
Reactions: 2
Thanks for that Rolex.puts my mind at ease on brake issue .the noise is coming from under seat and mechanic told me it was pump .abs light is working as normal and diagnostics are clear
I would take a short ride & find a good bit of road or grass, then lock up the rear wheel in a controlled manner, you should feel a pulse on the brake pedal.
This will confirm your ABS is working and no light should be up on the dash.
