I recently purchased (for a good deal) an '07 650 from my cousin who hasn't ridden it for the past two years. There was even fuel in the tank from 2 years ago.
After replacing the battery and an oil change, the bike started right up. I pumped the tires up and took it out for a ride. It was great. No problems.
I have been riding it for the past few weeks now with no problems until today. On my way home from work, I was doing about 65 on the back roads. I was going up a long hill (Central PA) and decided to give it a little more throttle. I noticed that no matter how much throttle I gave it never went beyond 5K rpm (speed was slowly coming down because of the uphill). On the downhill, samething--> couldn't go beyond 5k rpm but speed went close to 72.
After a few more hills of doing this, I was on a flat road. Now when I gave some throttle, The bike started slowing down.:jawdrop:when i relaxed the throttle, the bike accelerated back up to 55mph. When I gave it more throttle, the bike would slow down and when i relaxed on the throttle and got to a certain point, the bike would speed back up to 55. Ofcourse, when i relax further, the bike slowed down. This happened in 6th gear. I tried it in other gears and had a similar result but peaked out a different speeds.
It was almost although the engine was not getting the fuel to burn. The fuel level was full. Filled it up two days ago.
I have no idea what could be causing this. Is there something that I should be checking? What can I do to fix it? Should I have done more repair/rebuild work before taking the bike out? Please help........
