1 - 20 of 105 Posts
Vendor
:thumbup: The Nissin Radial Master Cylinder effectively transforms all of your DL650 Models and the DL1000 motorcycle braking system bringing your bike up to the standard you are hoping for at a price far less than Brembo but with performance that will make you feel like you have one.
Visit me anytime at SV Racing Parts | Your source for the best SV and VSTROM motorcycle parts and go under For Vstrom Riders and then performance Parts. Checkout anytime you like with the shopping cart.
Discounted from MSRP Price of $254.99 to $214.95 for Stromtroopers,
This is the very best reasonable budget based Front Brake Master Cylinder fix and Upgrade to get rid of the spongy feel and pull on the DL650 and DL1000 Front Brake Levers. Comes complete with all mounts including Remote Reservoir Cup for your brake fluid and mirror.
Enjoy Greater Adjustability to control brake lever feel and performance.
Comes complete with Brake Fluid Reservoir Cup, Hose, and Mounting Bracket,
Complete with Mounting Bracket for Right Hand Mirror same as OEM.
Complete with Plug in for Rear Brake Light Control Switch as per OEM.
Bolt On Ready and will work with the OEM Hand Guards for our bikes,
Priced Right for the Rider wanting the best brakes for our bikes to complete the SV Racing Parts, 4 Piston Brake Caliper Upgrade.
The Nissin Radial Master Cylinder is in stock and ready to ship to Stromtroopers today
Email me Directly anytime you like at [email protected] or use the Contact Us link at the top of the web page, No PM Please,
Everything is in stock and ready to ship today,
These are all excellent parts that will serve you well,
Blair
DL1000 brake upgrade, this ain't no farkle
I'm new to the forum but have been checking it out a lot since I bought an '04 V-Strom 1000 last year. I appreciate the help. I saw talk about the Master Cylinder upgrade and decided to try it. My DL1000 had pretty good brakes, but my last bike spoiled me for better. The Nissin Radial Pump Master Cylinder, along with Galfer SS brakelines, gave excellent brake performance improvement.
It only took an hour to remove and replace the OE master cylinder and brake lines. I tightened everything to spec, mounted the reservoir and filled and bled the system. The built in bleeder on the Nissin MC (which saves $20 on a double-banjo bleeder-bolt) made it easy to get a very firm lever in about half an hour.
The OE brake light connector fit without problem. The only adaptation I had to make was in mounting the OE handguards. I ride in the cold plenty and omitting them was not an option. I had to remove the pivot bolt from the OE master because it has a mounting boss on the top; it fit the new MC. I made a mounting extension from a piece of aluminum, drilled and painted it and mounted it with stainless hardware that I got from Lowes.
I didn't replace the OE brakepads because I wanted to test the new MC with that variable removed. I have about 200mi on it now and am VERY pleasantly surprised by the difference the Nissin MC and SS brakes lines made. It was a very obvious improvement, NOT incremental. The brake power is much greater and the feel is greatly improved too. I can't say how much the feel is affected by the SS brake lines. The difference is remarkable and better than I had hoped for.
Knowing what I know now, I would have replaced the MC even if it had meant paying for some Bark Busters to replace the OE handguards. That's something that I previously thought was a deal-breaker. WOW, The improvement is SO worth the money! I had no idea what to expect, but this mod will be in my regular bag of tricks from now on. I can't wait to put on the EBC HH pads I have sitting in my garage. I'm afraid that will mean some new fork springs soon.
Vendor
Blair
Vendor
Blair
Vendor
Blair
Vendor
Blair
Vendor
Email me Directly anytime you like at [email protected]rts.com or use the Contact Us link at the top of the web page, No PM Please,
Blair
Vendor
Blair
Vendor
Blair
Vendor
Blair
Vendor
Discussion Starter #11 (Edited)
Blair
Vendor
Blair
Vendor
Discussion Starter #13
Blair
Vendor
Discussion Starter #14
Blair
Vendor
Discussion Starter #15
Blair
Vendor
Discussion Starter #16
Blair
Vendor
Discussion Starter #17
Blair
Blair,
Perhaps you could expound on how the round shape of the master cylinder reservoir improves braking over the stocker.....:confused:
Vendor
Discussion Starter #19
Blair,
:) The round shape of the Master Cylinder Reservoir has nothing to do with the improved braking. That is all about the larger Bore and the Stroke of the Radial Master Cylinder itself which is a whole new universe of improvement over the oem.
In short Radial is a much bigger and powerful braking system than the oem.
Think in terms in the difference in braking power with 4 wheel Disc Brakesr today and the way drum bakes worked in the past on your older cars. That is the braking change between the Nissin Radial Master and your oem Master,
I hope that helps you put it into perspective, Your Bike and your Brakes will Thank you when you make the move forwards,
These are excellent parts that will serve you well,
Blair
Has anyone bought this unit? Can you share your experience with it?
Blair, has anyone given you positive feedback on their purchase that you can share here?
I'm all for doing what I can to improve braking. The ss brake line I needed to install when I added 2" Rox pivoting risers and was very pleased with the results. I've just never heard of this upgrade.
Thanks!
1 - 20 of 105 Posts
