New Wing Mirror Indicators
187 views 7 replies 7 participants last post by  Yarz1
#1 ·
Hi there all 😁
I've decided to fit these wing mirrors with indicators in them. I don't really want to hack into the original loom so am looking for a male and female indicator to make a plug and play 2 into one connection. Any idea where i can get them from or what they are called ? Many Thanks 😎
#3 ·
Before cutting the OEM turn signal connectors off, just to make sure you like the new mirrors; cut the connector off of the new mirrors harness, strip back the insulation about a cm, then push these ends into the back of the OEM turn signal connectors. Test to make sure they are making good enough contact, then use a plastic wire tye to hold the wires in place.
Once you have decided you like the mirrors, then you can make the connection permanent.
#4 ·
Lockhart-Phillips use make some conversion wiring with OEM connectors on one end, both ends, and splicing in two wires. Not sure if they are still business or if they still make them.
I would cut the connectors off the mirror wiring, then connect them to the turn signal wiring with Posi-Tap connectors.
Posi-Lock website
#6 ·
I'd contact Eastern Beaver. He seems to have all kinds of hard-to-find OEM connectors of this sort. (Also, wow, they've updated their website from its late-90s patina!)
#7 ·
I think they use Mitsubishi ultra compact connectors on the bike.
You could make your own adaptors.
