New V-strom 700 maybe?
5927 Views 47 Replies 28 Participants Last post by  PerazziMx14
Hi, could this be the new parallel twin Strom?
Reactions: 1
1 - 20 of 48 Posts
Sure looks like a V-Strom without a V. Lots of components and styling that look right off the current Stroms.
Upside-down forks would be an upgrade for the entry-level bike.
Does anyone know what he is saying?
Reactions: 1
There have been a few articles out there in the past couple of years about a VStrom 700 parallel twin as a replacement in the next generation although wonder if they will keep the VStrom name with a parallel twin. The release has likely been delayed due to the pandemic.
This is a popular bike in Europe, would not be surprised if it appears there a year or two before North America.
Ah, the new PStrom. The 650 would be the PWee.
Now, we could easily get a shaft drive.
Reactions: 5
Ze Germans! :oops:
Their calendars are goofy. 2022.07.06 o_O
That video came out a few days ago, yet I can't find any other info about this V-Strom 700. Where did that guy get that picture from?
Those were definitely spy pics of whatever the new bike is called. You can tell they added layers of who-knows-what to partly disguise its angles, just as manufacturers always do.
I tried to use an auto translate, it was iffy but here's what i remember:
No quickshifter
Cable Clutch
Modern forks with real adjustability, not just preload (upside down forks)
Updated front brakes
Modern LCD all in one instruments
Still has remote preload adjuster for rear
21" front 18" rear (I think he said spoked only)
270° crank separation for sound
I'm sure I forgot 20 things
See less See more
I read somewhere that V twins are not going to be able to meet Euro emissions at some point. Can't remember why cost considerations?
That's why all the new models are parralels.
From what little I know about engines (very little) Harley Davidson keeps upping the engine size because that's the only way they can comply with emission standards while still using their non-liquid cool V twin engines. The Euro standards are even more strict than the US so it makes sense for Suzuki to go with a parallel twin as they're not going to keep making bigger V Twins just to comply with standards. Why are parallel twin engines better suited to comply with these emission standards but not V twins?
Parallels are less expensive to build and are easier to package. 90 degree twins are easier to balance. There is much written about the pros and cons of each type of engine.
Reactions: 4
Right, but why is a parallel twin easier to get to comply with emissions than V twins?
How is upping displacement making it easier to comply with emissions?
The left side engine in the video case looks like the left side case in the drawing.
Those brakes sure look like existing DL650 brakes. I guess they could be bolt-on four-piston versions though.
See less See more
V-Twins (the strom is really an L-twin) are just more expensive to build. They are not inherently more polluting. If the video is accurate, the parallel twin strom may be getting a 270 degree crank, which gives the same firing sequence and torque characteristics as an L twin.
If I’m not mistaken, Ducati is still using a V configuration. Likewise the GS. Can you imagine a GS with a parallel twin. There would be a bunch of Schubert helmets exploding and power ranger suits on fire.
Reactions: 1
A GS with a V-Twin?? Well Harley did make an opposed twin boxer engine during WW2.
Reactions: 2
I could have done a better job there. What I meant to say, the GS has a boxer twin with separate cylinder heads. It’s early still… more coffee.
  • Haha
Reactions: 1
I think the reason engines are getting bigger is due to tighter emissions. When producing lower emissions, less power results so engine gets bigger to please the customer's desire for power.
Reactions: 2
& jus look at those wheels.....old style 3 spoke from 2016!
Now THATS progress
I don't know.
Now THATS progress
I’m curious why they stick with the 3-spoke design. Seems like 5 or even 7 smaller size spokes would be lighter or stronger, or both. Can anyone enlighten me on this?
1 - 20 of 48 Posts
