New rider Q: How often do you wash your bike, clean your chain?
3603 Views 36 Replies 30 Participants Last post by  RDY4ADV
New rider here with four quick cleaning questions.
1) How often do you wash your bike?
2) How often do you clean and lube your chain?
3) What do you use to clean it/to lube it?
4) If you have tried the cleaner "Bike Brite," how well did it work? It seems to have great reviews.
https://www.amazon.com/Bike-Brite-M...962&sprefix=motorcycle+cleaner,aps,89&sr=8-25
Thank you.
1 - 20 of 37 Posts
1) Unless it gets covered in mud, infrequently. Usually before dropping it off for tires or if I'm going to be working on it. If the car gets washed I'll often wheel out the bikes and wash them as well.
2) Have a chain oiler. "Clean" is wipe down with a paper towel as a gas station if it's really dusty (often is here)
3) ATF Relatively cheap, doesn't attract dirt badly, very consistent
4) If you really need very dirty to very clean, truck wash is the go to BUT you have to wash it off completely afterwards and ideally ride the bike until it's dry. (Tends to eat aluminium if it's left on there)
IF (and only if) it's a new bike. Ceramic coating is the way to go. Doesn't cost much for enough to do 20 bikes. (~$50). Won't work if the bike starts dirty.
dirty bike is a theft deterrent when parked next to shiny bikes
Reactions: 2
1. During the normal course of riding, never. Although I've been known to give my headlights a wipe. But I might give it a rinse before maintenance to keep myself a bit clean.
2. Never. I've got a Scottoiler chain oiler which keeps a thin film of oil on the chain, so dirt just flings off. In the past I used a wax spray and tried to apply it at every fill-up (300 km or so). But, like others, I always overdid things so at every service I had to go into the front sprocket area to scrape the excess wax, mixed with road grime, out of there. Messy job. For this reason I would not recommend anything that solidifies (like wax) to lube a chain. Always use something that stays liquid, like oil of some sort.
Reactions: 2
For me I oil the chain after alomost every tank fill up (thanks to VTom) and clean my shield as needed to be nice and clear. Washing the bike maybe once or so a season and only when really dirty etc. And then once before winter storage. Chain never really is cleaned if well lubed. I do occasionly give the tank and instrument cluster a quick rub down.
Reactions: 1
Depends on which bike. The Wing gets lots of bugs on it and try to wash it after each riding event depending on the weather/temperature. No bugs yet but it hasn't been out of the building yet either. No chain, no maintenance/cleaning.
V-Strom gets washed after a muddy or dusty tour of the logging or forestry roads. Not much chain "cleaning", oil it with chainsaw bar/chain oil aprox after every other outing. New chain/sprockets last season.
Always wash at home. Hose and bucket w/Dawn dish soap and Zip wax solution. Cleans and beads water well. No car wash or pressure wash.
I don't spend a lot of time with cosmetic appearance on the V. It's got it's share of character marks with more to come.
Wheel Tire Fuel tank Automotive fuel system Automotive lighting
See less See more
Reactions: 2
A bucket, some car-wash soap, a microfiber cloth and a low-preeure hose to rinse takes care of everything except rear wheel, chain guard, chain and sprocket(s)
Wet cloth on windshield while washing rest makes it easy to clean without scratching.
I follow up with a coat of Carnauba Wax on all painted surfaces and polished steel (fork tubes)
That is once a season and allows a good overview of condition, etc.
As for the chain, Every tank or so, wipe down with a cloth to remove surface dirt, apply new chain lube (for me, 75w gear oil) and wipe again to remove excess oil and dirt.
Ride, repeat as needed.
When rear wheel gets sufficiently coated with oil/dust, a rag with either kerosene, WD-40, or paint thinner will easily remove the gunk and the rim can be polished with a soft cloth afterwards. This is also the time to clean out front sprocket area. A small paint brush and som kerosene works nicely for this—fresh lube after.
No strong cleaners/detergents/degreasers, NO power washers, no chain waxes and no Armor-All.
Tire Wheel Fuel tank Vehicle Automotive lighting
See less See more
Reactions: 3
I wash it when it gets dirty, usually bugs. I like the Dupont teflon chain lube since it dries dry and doesn't attract dirt. I typically lube it after rain or maybe once-twice per month.
Rejex is a great wax type product. Multiple coats provide a DEEP shine.
SC1 is a great easy spray on silicone polish. Advertised as "New Bike in a Can" and I am a firm believer. Smells good too.
I use a garden hose and one of those garden hose-end sprayers filled with car-wash soap. That'll melt away a lot of dirt. Just dial in the desired amount of suds. Then (every so often) I'll take a wash mitt to it and then give it the "once over". An occasional detail will will help to detect any issues before they become problems (i.e. loose fasteners)
Material property Font Gas Paint Toy
The chain gets lubed every few hundred miles with something in an aerosol can with the words "chain lube" on the label. . When it gets really cruddy, it gets sprayed down with WD-40 and left to soak overnight. A good wipe-down the next morning with an old thread-bare terricloth towel usually does the trick.
See less See more
Reactions: 1
This is a good plan, the hose-end sprayer works great for distributing soapy suds. The WD-40 does a great job removing chain grime and keeping the o-rings moving well. You don't want WD-40 on your pads or caliper, so I take a few paper towels folded over on each other, then place them between the chain and the chain slider on the upper section of the swingarm just behind the pivot. Spray the section of the chain over the towel. Roll the rear wheel forward so a new chain section is over the towel, repeat. Wipe off the excess with clean towels. Apply some gear oil using something like an Elmer's glue bottle. A really great chain oiler is called Tutoro.
1) once a year
2) never/ every 1000 km
3) nothing / S100
4) Bottle Liquid Drink Glass bottle Alcoholic beverage
See less See more
I rag wash my bikes when they look dirty, don't ever hose down. Chains get wiped off with a rag and WD-40, I don't ever lube a quality modern x or o ring chain. Good for 30k with that routine.
Just did 1200 miles on my Ducati in 2 days of rain and snow - didn't look at chain and don't plan on it.
when I wash my bike I always use S100, love that stuff.
Reactions: 1
I have a Tutoro oiler and just turn it up a lot while riding when I want to clean it. Have not touched it since I bought the bike 20,000 KM ago. I do clean the wheel of oil and Gunk and use S100 cleaner and a bristle paint brush followed by a rinse and blow with compressed air probably once during the year and once in the Fall.
Reactions: 1
Bucket,Meguiars car wash,micro fiber towel when dirty.Finish with Bike spirits wipe down.
Wet towel on windshield, mirrors, front of bike,after almost every ride to keep bugs off.
Clean chain with wd40 and rag, lube with gear oil every 2 tanks of gas.
Tire Wheel Vehicle Fuel tank Automotive lighting
See less See more
Reactions: 1
I clean the windscreen, headlight cover, turn signals, brake lights and instrument panel whenever they start looking dirty. I've had the bike 4 years now I think and I've never washed it. It's dirty. I wash all my other ones but for some reason the Vstrom has always seemed more "utilitarian" to me, not that I don't care about the bike, I just don't care how it looks. Still my favorite bike I've had so far.
Chain - I use PJ1 blue label on it. Lube it every 3-4 months or whenever I'm bored and happen to be in the garage.
Soap - I bought a foam cannon from harbor freight and used it on my corvette. I really like it. You will go through more soap but it covers nice and thick.
Washed when I ride it in the rain. Clean screen when needed. Chain wiped off once a month and lubed when I change oil about every 3-4 months with Dupont, even though I really don't think it needs it.
1) How often do you wash your bike? When ever it rains while riding.
2) How often do you clean and lube your chain? Clean, never. Lube when stopping for the night or end of ride.
3) What do you use to clean it/to lube it? I lube with DuPont Chain Saver.
4) If you have tried the cleaner "Bike Brite," how well did it work? Never used it.
Rectangle Font Art Pattern Diagram
See less See more
Have you heard of the Snoto chain cover? Snoto CleandisC Chain Guard Review Video
Got one on order. Am looking forward to hopefully making rear wheel cleaning a bunch easier and less frequent.
1 - 20 of 37 Posts
