1 - 1 of 1 Posts
I'm about to install the Denali 2 lights and I have a couple of questions.
Is it necessary to remove or lift the tank in order to bring the wiring up front? So far with every modification I've been able to run the wires with relative ease, but the wiring with this kit is much thicker than what I've used in the past.
Does anyone know if after installing the EB H4 dual relay the unused H4 headlight connector is still hot? Can it be used to tap into the high and low beam wiring?
1 - 1 of 1 Posts
