1 - 19 of 19 Posts
I camp about 60 days a year. I'm always charging my phone, blue tooth helmet, etc. I've been using my SAE plug coming from battery for battery tender with a female cig plug.
Decided to run an un-switched double USB plug to help facilitate more charging options.
Nice clean install.
I've read that sometimes USB ports have a parasitic draw even when nothing is plugged into them. Don't know if it's true or applicable in your case.
I ride my bike year round. Think the draw would be negligible, if any. But it is a locking cig plug USB, that can easily be removed and left as an empty socket if need be.
I stuck one on the handlebar and made it switched.
That just duplicates the factory one. I wanted one that can charge with key in my pocket.
Right - I needed another port up front but changing it to non-switched is as easy as moving the wire in the Eastern Beaver PC-8 fuse box to one of the two non-switched circuits. Maybe 2 minutes. I have the Battery Tender Jr plug under the seat if I need it as well direct to the battery but I am afraid I would forget once and get stranded. lol I could toss my 2000a Genius in the top case for a big trip. ;-)
Ha ha. Yeah, I have the battery tender SAE plug right next to my new port. I can charge 3 things while I sleep now. Geez. Try to get away from electronic devices while I travel. Look at me.
I have not done a very good job of getting away from electronics devices. lol
I have mine in the top box so I can leave stuff on charge and walk away.
I use the cigarette plug outlet I use to power the GPS with a 2 headed cord or put the phone in the tank bag using the single recharge cord overnight.
The USB is nice but not so versatile. I can back charge the battery using the ciggy plug too. And I can run the air compressor on that too.
Nice job 2stroke !
I agree that unswitched charging is very handy. I have a SAE dongle in just about that same location but on the left side. It is wired unswitched to the battery and I use it for my e-vest while I'm riding and I made up a SAE to powerport with about a 16" cord so I can put my phone under the locked seat to charge when I'm at lunch, etc.
Reactions: 2stroke
Discussion Starter #14 (Edited)
I have two cigarette lighter adapters. Actually 3, if I unplug USB, (1 switched, 2 unswitched) and 2 USB adapters. Plus an SAE plug for battery tender. My air compressor under seat will hook up to SAE or Cigarette adapter too.
"I can do that as well with my SAE plug."
Didn't think the USB would handle the current for a compressor. Totally cool.
I was thinking about the big 12 ga wire I have coming from the battery to the ciggy outlet.
The Stop-n-go compressor only draws about 6 amps. Some of the bigger ones go 10amps. USB 3.0 cables were limited to about 5 amps. I used the Battery Tender connected straight to the battery when I had several flats. It has a standard 12v power adapter that plugs in the their connector.
How do you like that USB plug? I have the Blue Sea Sky one, and the rubber cap sticks on there so hard that the rubber nub ripped off when I tried to un-cap it. Now I have to pry it off with my key to get to my USB ports. I'm glad that it is so well sealed, but it's pretty annoying.
Which plug is it?
1 - 19 of 19 Posts
