1 - 9 of 9 Posts
Take pictures before taking anything apart.....keep repeating........
New cush drive installed 06 wee, there is a 1/4 inch gap, the sprocket assembly should be flush? I can't push it down anymore
Super Moderator
Take a rubber mallet to it and ensure the sprocket carrier is going all the way in the hub. New rubbers is a "tight" fit, and that is a very good thing.
Thanks B,
But 1)should it be flush?,
2) Should I take it off and add a little lube, if yes, what kind of lube? small amount of tire lube, won't degrade rubber
So close to getting the wheel back on, don't want to mess up now, light at the end of the long tunnel
Just make sure everything in the hub area is clean. A bit of Windex won't hurt a thing. Like BigB says, tight is good! After the first time it will be easy.
Just install the wheel. The axel will push it in that last little bit. Hope you have the spacer in there and correctly positioned. The spacer will determine the final position of the sprocket carrier.
1 - 9 of 9 Posts
