1 - 20 of 28 Posts
It's official. Here's the new bike.
Pulls like a tank, great breaks and suspension. First things to do are:
1. Replace mirrors with my previous SV mirrors - done
2. Replace foot pegs with my sw-motech pegs - done
3. Install heated gear harness - done
4. Install Ram Mount X Grip for phone - done
4. Install barback/riser - not done. My Zeta barbacks don't fit. Any recommendations for a slight up and back?
5. Top case - still shopping.
That's it. Everything else is just the way it should be.
Congrats.
Gets even, much, better with some klicks on the ticker.
Those aren't the stock tires, right?
Right bike for you brother....can't wait to see/ride with you again.
Reactions: Rudderfeet
Congratulations! I can't wait to see it and ride with you again!
I was going to say I literally use the same up and back risers on my 2015 DL1000 that I used on my 2006 DL650 and on my 2012 DL650 and they should work for you but then realized (I think I read) the Adventure (XT?) version has thicker handlebars.
Congrats.
They are not. They are Shinko’s 804/805.
They gave me the stock Battlewings too.
That’s exactly what I thought. Just transfer them over. The new bars are definitely bigger.
Same with the foot peg mounts. To transfer my sw-motech pegs I had to use the new bike’s pins because it’s half an inch longer to get through the thicker mount holes.
What are the biggest/longest risers or bar backs you can install on this bike with the stock cables?
Looks like 25mm straight up is perfect. 30mm doable. Anything more and your playing with cables.
Swapped to 20w50 today. Definitely smoothed the bike out. Shifting is noticeably better. Idle hammer is still there. Clutch engagement seems smoother, but that’s hard to quantify.
I used to run 20-50 in my Vee. It does soften the 1-2 crunchy shift. I really don't see any negative to it, beyond I might not want to run it when temps cool down due to starting cold engines.
Forget about the Idle Hammer. Tell'um its Thors Hammer winding up!
Moderator
Congrats Eric! Really looking forward to riding together again sometime soon. Maybe I can convince the boys to come up to Kanuckistan next round. :)
BTW it pained me to sell my decked out 2013 DL650 last weekend especially after she was magnificent again in the Smokies, but I got a fair price and the buyer and his also-motorcyclist wife are already loving it. I'm still waiting for my 790R but hope to have it next weekend or soon after. It's nerve wracking to be without a street bike!
Discussion Starter #13
Thanks man! Likewise.
Waiting for a bike is killer, especially if you don't have one in the meantime.
It was hard to hand over my 650. Such a great bike and setup exactly the way I wanted it. The deal on the 1000 was too good to pass up and I got hooked on it after having it for the weekend as a loaner.
Discussion Starter #14
Lol, you definitely have to accept it as a characteristic of the bike, otherwise it'll drive you nuts.
Another option is get an exhaust so loud that you can't hear it :grin2:
Eric, I had extensive fender rubbing (melted the underside plastic) with the 804's when speed caused it to elongate. Are you aware of the riser kit for the front fender? FYI CE
Discussion Starter #16
This is the second report I have read on the 804's causing this.
I am aware of the fender riser kit from ADVTECH. I had it on my 650. Looks like I'm in for a redo on the 1000 if I want to avoid that scenario. Will the 0.65 inch kit suffice or do I need to go with the 1.6 inch kit?
I did hear some strange noise on the highway the other day. I bet that was it.
You forget all the work you put into a bike... until you get a new bike :grin2:
Nice bike! And west-end Ottawa, I grew up there.
Reactions: Webfors
I went with .65 but had to abandon the ABS keeper clip on back of fender to allow for clearance.. I don't see any negative impact to letting hose line ride loose. I didn't hear any rubbing but noticed a small crown on melted plastic on the back lower edge of fender when I got home... I was a little pissed at Suzuki for providing so little clearance on an "Adventure" moto... Loved the tires in the sands of Nev. last year and will use them up on ID BDR in August... Let's go baby!!!"...
Discussion Starter #19
Thanks! Just ordered the .65 kit. I also love these Shinkos. Had them on my 650 for 5000km down to the rally and back. They tore up every road I threw at them.
1 - 20 of 28 Posts
