1 - 9 of 9 Posts
I can't for the life of me find a passenger backrest for my 2014 DL650 Adventure. I had a Givi top case that has a pad but its ridiculously oversized and does not feel good for the passenger.
Why can't I find a simply backrest to put on the bike. I ordered one from bangfabrication on Ebay that said it would fit my model, but the holes just don't line up. They offered to refund, but I might keep it and have someone custom fabricate a bracket or plate to affix this back rest on.
Corbin Canyon saddles have attachment points for both the rider and passenger, their backrest is really nice. Not many options out there for stand alone backrest for passengers, unless is part of the seat.
Thanks.. I looked at the corbin seats but they are bulky and pretty ugly.
I guess I will just have to fabricate something. Bummer.. Just surprised that no one else rides with a passenger without a top case..
I was also looking for this, and I found a couple, but they are crazy expensive (over $200). Rather just buy a top box.
The Suzuki VStrom Stealth® Backrest from Pirates' Lair at 828.628.7093 EST - "Customer Comments" section mention this backrest fitting the 650 ...
try Googling this - "vstrom backrest" - then click on the Images button - that's how I found the above link ... looks like your backrest and rack is shown too - although one of the pages on the dynamic website indicates they have other rack plates that may also be able to accommodate your GIVI box (and their backrest when the box is not in place??) - maybe that's a fix for what you have on hand?
as far as your GIVI pad being thick - cover staples come off easily with old screwdriver tip - then we used a long serrated ("Bread") knife to thin out the pad and then reinstall cover with staple gun - cover has an elastic band around it to help hold it in place - sucks down pretty good after trimming the pad thickness - looks factory - took my wife about 20 minutes to fix up ours how she wanted it ... trimmed a bit, put on her riding jacket, sat the bike, adjusted a bit more - tried it again - done
Good luck!
You should compare a Corbin to an RDL or a Terry Adcox saddle and compare bulky and ugly to the Corbin. :grin2:Yes the seat pan is actually a seat pan, and the seat itself weighs a ton compared to the OEM and perhaps some others. The removable and adjustable back rests are so awesome from Corbin, and that is what my Wife uses instead of the top box pad "which she says sucks".
This is bulky and ugly? :confused:
OEM top case as a back rest was too far forward for my wife. I bought an OEM mount for the top box, cut the supports and bolted it to the top box plate that came with the bike, but moved it rearward about 2 inches. Now the top box is back far enough for it to be comfortable for the wife. Best part is it is super easy to change back to it's original position.
Wife!? You’ve got a wife??
1 - 9 of 9 Posts
