1 - 10 of 10 Posts
Hi, I have a center stand but some times I would like to leave the bike on the side stand but it drives me crazy on how much it leans.
Is there a bolt on solution , maybe from another bike?? or has anybody found a good way of modifying the stock (making it longer ).
Wow, I've honestly never heard that one before. The strom has a pretty conservative lean angle for such a tall bike. Take a look at a couple KTM's or tall bimmers if you want a lean angle.
-GW
No longer riding.
I added raising links to the rear and that made the ange even worse. I really could not see a good way to add to the bottem, so I cut the stand and added 2.25" in length to the shaft.
The bike now has a nice lean angle, not to straight but over enough to feel safe.
My bike leans over like a drunken sailor. When it's fully loaded I have to be careful where I park it so I can get it back upright.
"Lean Angle" Problems
There are a lot of guys out there who wish that their sidestand was longer and sturdier, but now there is a product that can fix all your "lean angle" problems. Take a look at http://www.extenze.com. This product will increase the length and girth of your "side stand" in the short time period of one to ten weeks.
I think he's got you there. :p
A longer kickstand will make the bike MUCH more likely to fall over in high winds! The mattress mate's SV650 is lowered 3/4" and it has fallen over on very windy days at least 3 times. You wouldn't think such a small amount would make a difference but it does.
Ever parked on anything but a flat surface? An extended stand may come back to bite you when uphill is to the left of the bike and its the only way you can park it. +1 on wind taking down the bike easier, too. Just a heads up; to each his own.
If you insist in making the thing longer try cutting a block of wood to fit the sidestand foot. In fact make several from 1/4" plywood and stack them until you get where you want to be. That way you know how far to go if you actually get to cutting metal.
Scroll down in the link below I have a picture of how I added a piece of plate aluminium to the side stand (added 3/8") after adding raising links.
You also get the side benefit of a bigger sidestand footprint. I also added the same type plate to both centerstand feet so the rear wheel would spin when it was up on the sidestand.
http://www.stromtrooper.com/showthread.php?t=17899&highlight=aluminium
1 - 10 of 10 Posts
