Went down off-road and crushed one of my turn signals. Decided to go for flush-mounts and tried out some LED versions. Unfortunately, I do need the flasher control unit that replaces the stock relay to control the flash rate with the LED signals.
Can I get to the stock relay without tearing apart the front of the bike?
Thank you for any help!
I rock at logic
Under your seat between the gas tank mounting bracket and the battery.
Note: According to the service manual the turn signal relay is also the side-stand relay.
Thanks!
Thank you all - that's what I needed.
