Has anyone set the tumblers in the lock sets for the plastic panniers?
Regarding the instructions -
I cannot make the measurements on my key match the width choices on Table 2.
For example, I measure B on Table 1 to be 1.5mm. Not even close to an option on Table 2. My key has a notch the same size as B.
Any wisdom is appreciated.
Musical instrument Font Music Material property Handwriting
Handwriting Font Material property Rectangle Parallel
Discussion Starter · #2 ·
Oops. Finally figured it out. I needed to measure the gap width vertically instead of horizontally.
I'm not the smartest person in the room, but a couple of measurement arrows in the instructions would have been helpful.
Reactions: Solarguy
Discussion Starter · #4 ·
I'd of just kept changing the tumblers until they were flush with the clock🤯
You are so right. I did not have a caliper, so I was measuring with a tape measure, then converting inches to mm and only got 3 of 5 tumblers flush. Then I just started changing tumblers as you mentioned.
