I have read the other threads on the aux connector on this site and not found this problem. I have a 2014 DL650 V-Strom ADV, with the anti-lock brakes, US model. I got the aux connector wiring from Eastern Beaver and I intend to connect it to a USB charging port. I found the connector, thanks to another thread here and I got it plugged in.
The problem is that even though my battery is charged and I turned the ignition on, I used a VOM, properly set up, and there is no current running through that circuit. There are no blown fuses, I checked them all. The owner's manual doesn't even list the aux as a circuit running through any of the fuses. I also consulted a DL650 schematic in a service manual and the aux connector does not seem to be on there. The heated grip connector is, but not the aux.
I don't even know how to start diagnosing and fixing the problem. Please help!
Does it need to running, the engine I mean?
That's a "duh" on me! I should have tried that. I can't do it until tomorrow. It would be strange, though. Most everything comes on with the ignition switch.
Even if it works, I would still like to know what fuze that circuit runs through.
I will post back what I find out tomorrow.
Super Moderator
I used the heated grips connector as my auxiliary power supply. Living in Queensland I have no need for heated grips.
The engine doesn't need to be running, ignition on will power the port. It runs off the ignition fuse so it is not a fuse problem or the engine wouldn't run. Did you put the VOM on the wires from the Eastern Beaver adapter?
I figured it out and the advice that is on the ignition circuit helped. It was a blown ignition fuse. It looked good when I first checked it, but in retrospect must have been bad lighting. My bad. I appreciate the responses.
I do have a follow up question. I am concerned the 10 amp fuse in that circuit might not handle both the ignition and the USB port. Would it be safe to put a 15 amp fuse in that spot? I don't want to be at a stoplight somewhere and have to undo my phone from the USB port to be able to start the engine, out of fear of blowing fuse. I know I could switch the hookup to the heated handgrip connector, but I'd rather save that for something else.
The circuit is designed as is for up to 3A at the AUX connector. That is plenty to handle any phone or GPS charging. I wouldn't consider upping a fuse rating, especially by 50%.
