Ok, I did a search and found out which wires I should hookup (I think) but I can't find them. I'm going to install the lights per Option 1 of the Dinali D2 Wiring Instructions with a D2 wire connected to the Moto High Beam Wire and another D2 wire connected to the running light wire. I have a 2011 Wee Strom w/ ABS.
Correct me if I'm wrong, but according to the online info..I'm going to connect the D2 100% Intensity Trigger Wire to the Moto's headlight high beam wire..which I'm assuming is the Yellow Vstrom wire which is located in the Forward Harness Connector inside the left fairing. I looked but I can't find it. The only yellow wire I see is coming from the moto's left side lamp. Can I connect to that? (See photo in link below)
I'm going to connect the D2 Switched 12 volt power wire to the Rear Brake Switch Connector wire which SHOULD BE in the connector just in front of the battery. Instructions I read said it should be inside a two-connector with an W/B wire. I looked but I can't find it. All I see are two big wiring bundles in front of the battery. I do see an O/G wire out of one of those bundles..can I connect to that? (See photo in link below) BTW, the Orange/Green wire looks Yellow/Green in the photo but it IS Orange/Green.
Again, I'm assuming I read the instructions correctly. Any help would be GREATLY appreciated. Photo link below. Thanks Rob
https://picasaweb.google.com/113815612903691627931/VStromLightWiring#
