1 - 3 of 3 Posts
I am having a problem installing VVME HID 5000k Ultra Slim H4-3 system on my 2004 DL1000.
Have everything mounted. When turning on lights, one lamp ignites and remains lit, the other flashes on then nothing. I have tried swapping connections from one ballast to the other, each bulb will remain lit if plugged into the left ballast. Right ballast only flashes on briefly. I am getting voltage output with my meter on the right ballast, so not sure why it is not remaining lit?
Any help or suggestions would be greatly appreciated.
Thanks.
It sure sounds like a bad right ballast. Invoke the warranty.
Well, I have since found if I cycle the ignition about 5-6 times the right bulb will remain lit.
Grrr.... frustrating, I will button it all up, and ride tomorrow. I will call VVME on Monday to see about replacement ballast.
1 - 3 of 3 Posts
