The coolant bottle is in different places on different bikes. Yours should be accessible by taking the black plastic boomerang shaped piece off from beneath the left side of the fuel tank. It has one screw in front and plastic spear heads in rubber o-rings on the back that simply pull out. You need to drain the coolant from the block too. It's in the position of the lower A marked bolt in the picture. The pic is of a DL1000 so yours will look slightly different. Only take that bolt out and coolant will dribble out. Break the vacuum by also removing the radiator cap and it will shoot out.
It's best to get a better shot at the radiator by removing the cowling. At some point, you'll need to get at the air filter so you might as well learn how at Fuel Tank Removal How to, 650 & 1000
