I went to jump on the bike to ride to work this morning, and found my clutch lever nearly worthless. It's got just enough resistance to return to position.
Then when pulled, it seems only about the last 3/4" of pull is having any effect.
I started it up, put it in first and it stalls after a fairly stiff shift. I started it back up, let it warm up a bit, and the shift still wasn't normal, but it didn't stall. I probably shouldn't have ridden it the 20 miles to the shop, but I was already in no mood to unhitch the boat and run my truck today.
The clutch reservoir is full and the oil is clean as new. I played with the adjuster wheel on the lever thinking maybe somebody's kid jacked with it over the weekend, but that affected no real change.
What would cause your clutch lever to not fully release the clutch, and how big of a tool kit do I need to fix it?
I don't believe it to be a leak, as the reservoir is still full and there's no puddle.
