1 - 10 of 10 Posts
I posted a while back about having difficulty putting my bike up on the center stand. I always have to put the back tire on a board in order to do so. So that got me inspecting the bile; my wishbone is stock, so perhaps I have an aftermarket rear shock? I also noticed there is no adjustment screw on this one like the stocker is supposed to have.
Can anyone tell me is this a stock or aftermarket shock in the pic attached?
Looks like a stocker to me.
I agree - that looks like the stock shock. The compression adjuster should be on the bottom clevis, on the left side.
Looks stock to me too. It could have been modified however. I think the small screw adjustment on the bottom left is rebound only?
Really hard to tell from that pic, but I agree it appears to be a modified stock unit.
Reactions: talonstrom72
Yes. My mistake. It does not do much to alter the harsh feel of the shock, either way.
Maybe the suspension setup has been fitted with shorter dog bones to lower it. This would make it harder to get on the centre stand.
Well I looked at the dog bone and it is stamped the same as the stock one. I will measure it at some point.
BTW, my rear shock has no little adjustment screw like manual says it should have, looks like it might be a rebuilt sticker perhaps? Maybe that's why it is so difficult to get this bike up on the center stand. I always have to put the rear wheel on a board first.
You could always post in the wanted section here, typically some OEM shocks out there just sitting around collecting dust. Or Ebay almost always has some shocks, buy one cheap and get it rebuilt with proper spring weight and valving for your weight and riding style.
From what little you can see of the shock in the picture, it looks just like the OEM one I pulled out of my K7 Wee last night. Can you post a couple pictures of the bottom sides of the shock?
1 - 10 of 10 Posts
