Mysterious Metallic “Bang/Clank” Sound on My V-Strom 1000 (2017) – Any Ideas?
4 reading
0 views 6 replies 7 participants last post by  Steve _H80
#1 ·
Hi everyone,
I own a 2017 Suzuki V-Strom 1000 DL, and I recently heard a sudden metallic “bang / clank” while accelerating uphill at around 40 km/h in 2nd gear.
It was a short, sharp, metallic impact — like metal hitting metal. There was no smoke, smell, vibration, or power loss, and the bike kept running normally afterward.
It actually happened once before, in 1st gear, but that time it was much quieter.
Here’s a short video where you can hear the sound clearly:
I’ve checked for loose panels and obvious damage but didn’t find anything yet.
Before I start disassembling parts, I’d like your opinions.
Thanks.
#2 ·
Chain tension is correct ? If too loose it can jump the front sprocket....and at a worst case, bunch up and punch a hole in the case in front of the sprocket.
#5 ·
The tachometer bounces at the same time as the noise but I can't tell if the clutch was being pulled in at that time too.
If the clutch was not being pulled in the tac bounce would point to chain slip.
The front sprocket could be worn out enough to let it jump.
Reactions: Missing Link
#7 ·
I would be looking at the whole drive chain. Even if it looks good there is a possibility some lazy **** has replaced the chain and rear socket but left the front one in place (remember to tie the clutch lever back before removing the cover).
Hopefully it's this and not something deep in the engine.
