1 - 4 of 4 Posts
Ok, I was feeling pretty defeated yesterday when I wrote about my failure to mount up my new tires. I don't handle failure well and have always been able to work on my vehicles. Have I made mistakes? Absolutely but never have I been completely unable to finish a job. But today was a new day and I went out to the garage determined to see if I could salvage this debacle. The first thing I checked was to see if the tire was still leaking and guess what, it was not. But I was feeling like I needed to get on top of this failure and succeed so I dismounted the tire again and cleaned the rim and bead, put it back together again and just before airing it up I dabbed a little clear silicone on the divot I had made in the bead. I aired it up and WOOHOO!! it held air with no trace of a leak.
I got a lot of support and encouragement from other Stromtroopers here, thank you very much, and I listened to what you all said, I slowed down and tried not to fight the whole process. I worked on technique over brute strength and had a much better experience.
Feeling much more confident now I moved on to the front tire. Aside from struggling to get the bead broke, that one worked pretty easily.
Here are some of the successes and failures that I had through this whole experience.
First off, the cheapo 2x4 bead breaker works like a champ. Easily the best success of the whole undertaking.
I had much less success with the Zip tie mounting system popularized on YouTube. I bought these big honkin zip ties at Harbor Freight and I put a whole bunch around the tire and really had them cinched up pretty good, but no joy! In the end I cut them off and mounted them the old fashioned way.
Tire irons and rim protectors. I bought cheapo EBay rim protectors and they were soft and easily damaged. They were also thick and hard to stretch the bead of the tire over. The tire irons were a 3 piece set from Motion pro, eh kinda short and small, they hurt your hands to apply a lot of pressure on. There are probably better choices out there.
I also scratched up my rear rim pretty good on the first day because I was struggling with the rim protectors and got frustrated and quit using them. Much better at handling them on day two. No marks on the front rim at all.
I bought a cheapo wheel balancer on EBay and that also worked very well.
So, would I do it again? Probably , like most things you get better with practice. Am I glad it's over? You bet!
Awesome!
In a pinch I change my own tires. It's a 2 to 3 hour affair per tire. If my favourite tire shop which is 2 hours away is hosting a track day (1/2 hour away) I take it to them as they charge 15$ (can't remember if that is each or a pair) which is significantly cheaper than the local dealership which quoted me $80 a wheel to bring my wheels and have them do it.
I was a whizz at the tube type most of the time but tubeless I get help. Either at a buddy's with the tools or the tire shop where mount and balance is part of the cost.
It's kinda like knowing which battles I'm likely to win and fight those.
Well done Johnny B. I think it's some sort of right of passage to change your own tires. I did it for the first time last year.
I have no place for large devices or tire change stations, so small was in. I used the Motion Pro - Bead Pro for bead breaking and tire spoons. They're a little spendy but work incredibly well and will last forever.
I did the 24" zip tie method as well. That, with a spray bottle and lots of soapy water, and a milk crate to balance the rim on, worked well. (I can't emphasize enough the value of tons of soapy water to ease the way to success) Next time I'm at a bike show I'll splurge and get some of the Motion Pro rim guards, but I consider the scratches on the rim badges of honour for now. I could also use one more tire lever/spoon, as a large flathead screwdriver came into use - probably not well-advised. Balancing was done with balance beads - they seem to have worked.
1 - 4 of 4 Posts
