1 - 20 of 21 Posts
Hi all,
I bought a new 2019 DL650 a week ago and I am a little disappointed. This is my 5th Vstrom I have owned and my 2nd 650. Compared to my 2008 DL650 I noticed a few things that are now worse.
- Uncomfortable riding position and the seat is 2" narrower than before and hard as a rock. The seat pushes me forward and the riding position seems more sporty with less knee room as before I have already ordered risers for handle bar but I don't really want to spend $500 on a Corbin seat which is 2' wider.
- Vibrates a lot when more than 4k rpm. Already installed a 16 tooth sprocket and its better but still not great. Can cruise at 75mph a 5K rpm. compared to my DL1000 which i can cruise at 75mph at 4K. Might need to change back sprocket too.
- Very bad wind protection, fairing and bike is about 3" narrower than before and wind is terrible. already ordered a givi wind screen, hopefully it will help. not sure if anybody has installed wind deflectors
- Top case bracket is very small worse than before. I have ordered a givi mounting plate for top case.
I commute 50 miles to work each day and i need something comfortable. Today I rode my dl1000 and its more comfortable and runs smoother in highway
Anybody else has these same issues/complaints?
Cheers
There are footpeg lowering kits available from vendors on this site. Best bang for the buck seat mod I have done is the Seat Concepts recovering kit. Many have had good luck with the Sit and Fly seat cover. My 2014 had some vibes at 5,200 but I retorqued the engine mounts and did the 16T front sprocket and it's fine.
Not an exact comparison but relevant. I went from a 2007 Wee (Gen1) to a 2014 Wee (Gen2) whereas you went from Gen1 to Gen3. I was a bit disappointed by a few things as well but over all I am happy with the "upgrade" but I will concede that sometimes I wish I had my old bike back.
Seat: The stock seat on my Gen1 was unusable by me, killed my back. I upgraded to the Seat Concepts seat and it was perfect. The stock seat on my Gen2 is as comfortable as the SC seat was on my Gen1 so I did not upgrade but...
Riding Position: The Gen2 is much more cramped with the pegs higher relative to the seat and it gave me hip and knee pain. The peg lowering kit solved this problem.
Vibrations: According to the previous owner of my Gen2, the bike was viby from the factory but he was an ex-Harley rider so he thought it was normal. It was unacceptably viby right around 5K but I could feel it at all RPMs. He went to the 16T front sprocket to get the vibes down but it did not really help. I tracked down the main cause as a loose lower throttlebody boot-clamp which was probably never tightened at the factory. I also reseated my motor mounts and the vibrations are mostly gone but it is still more viby than my Gen1 which was smooth as silk all the way to red-line. I went back to the stock 15T front sprocket as I like that better for my style of riding and the vibes have been fine. I suspect that the compression is not even between the cylinders or the generator or clutch pack are out of balance but have not had time to pursue it. A 90deg V-Twin is in primary balance so it should not be viby at all.
Motor Mount Reseat & Retorque
Vibrations
Buffeting: I got spoiled on my Gen1 which had no buffeting issues whatsoever, I'd even forget to put my visor down on the freeway runs which is dangerous. My Gen2 was buffeting from the day I got it. Both Gen1 and Gen2 have vent holes on the left and right front of the fairing. These vents are suppose to provide a bypass for airflow so it doesn't run around the sides of the fairing and tank and into the rider. The problem is that from Gen1 to Gen2 Suzuki dropped a plastic skirt attachment under the fairing where the front forks enter the fairing. This skirt separated the vents from the airflow piling up in front of the radiator. Without that skirt those vents are doing nothing. I rigged some tubing between the front vents to behind the radiator and the buffeting was dramatically reduced. Unfortunately, the tubes are bit too small and they were a rev0, proof-of-concept hack and I had trouble keeping them in place so I removed them but they did work. My plan now is to try to install some kind of under-skirt as in the Gen1 design using leather or flexible plastic to allow the forks to move. There just isn't a lot of room for tubing inside the fairing.
Buffeting Wars
Read the Buffeting Wars post and wondered exactly where the tubes divert the air from the vents. I understand that the intent is to bring the air behind the radiator, but the vents in front are already above the radiator, from the photos.
Thanks in advance,
Mark
Read the Buffeting Wars post and wondered exactly where the tubes divert the air from the vents. I understand that the intent is to bring the air behind the radiator, but the vents in front are already above the radiator, from the photos. Thanks in advance, Mark
A picture is worth a thousand words.
First pic is the old Gen1 design (that works) and you can see how far the vents are from the high pressure zone that builds up in front of the radiator. In addition to being wider the under skirt helps to isolate the space behind the vents so they work more effectively in channeling air off the outside of the faring and behind the radiator.
Second pic is the Gen2 design (that does not work) and you can see how much narrower the vents are and thus closer to the high pressure zone. Without the skirt the high pressure zone almost certainly extends behind the vent and prevents them from moving much air at all. The air that doesn't go through the vent goes around the outside of the fairing and into the rider causing buffeting.
Third and fourth pics are the right vent tube installed and how it vents the air just to the side of the tank and out the side. The tube just provides a barrier that prevents the high pressure zone in front of the radiator from encroaching on the back side of the vents.
This is hard to describe and show in 2D pictures (it is a 3D problem actually) so if you ever have a chance to inspect a Gen1 and Gen2 right next to each other the problem and the fix is obvious. After looking at this project again I now think a skirt is a no-go. Attaching a skirt is just too difficult so its going to have to be tubes. The rev-0 design worked but wouldn't stay in place and I think to really put an end to the buffeting the tubes need to be larger anyway. I'm going to look into oval tubing or some other contraption that will fit and stay in place, just not sure when I will get to it.
I have a feeling that a lot of the vibration in these motors both 650 and 1000 has something to do with the mapping required to lean them off to meet modern emissions standards. I have always been of the opinion even since carburettor days that a leaner fuel mix makes for a harsher and vibier motor.
I've thoroughly enjoyed my 2009, but have been considering jumping to a gen 3. Threads like these make me pause. I don't want the newer rider aids, and the newer beak design doesn't appeal. I would like a lighter and more nimble bike, but beyond that it is probably just new-bike-itis. Thanks for some reality checking. I think the gen 1, especially the late models represent a peak of modern fuel injected bike, but without an abundance of electronics. I appreciate it for that reason.
I went from a ST 1300 to my '13 DL 650. Suzi is noisier, vibrates more, has less wind/weather protection, and has more wind buffeting. It also has a surprisingly comfortable seat*, is lighter, more maneuverable, lighter, easier to park, lighter, and more economical on gas, and lighter. I've spent a lot of money trying to remedy the noise/buffeting issue and put on the DL what I had added to the ST, with only partial success. I am, however, getting there, and realize that there are always tradeoffs. Nothing that the ST did well quite makes up for its weight when stopped, and while it made the miles disappear and erased the difference between 65 and 85 mph, I like the Suzi for exactly what it is.
They say you can never go home. I'd suggest you read a lot more threads here and start modifying your new bike. Don't look back.
*Sargent - it came on the bike. Oh, and the DL has way more storage in the side and top cases than my ST.
I've had my 19' a few months now and YES they are vibey especially around 5-5.5k. I also went down to a 16 tooth sprocket and this helped a lot to bring the revs down out of that range. Do you have crash bars? They act as giant tuning forks and exacerbate the issue which I am currently working through to resolve.
As for the seat I find it really comfortable but I came from a DRZ400E. I also put on the rox 1" back and up risers and they have transformed the ergos of the bike for me. Once I sort the vibes she will be a keeper.
Interesting theory but the empirical evidence is that the windshield and the mirrors are the cause of the buffeting.
How could those small vents effect the airstream over the windshield? They are there to direct more air over the hot mechanical bits more than likely. Tubes directing the air away defeats the purpose probably.
High pressure zone? Uh seems like the entire front end disrupts that, it's not like it's aerodynamic or anything! :grin2:
Sorry to sound like a grump, but this still is the 2017+ section, right?
Of course all are welcome, but so much content posted lately not relevant these model years. Could create confusion.
Empirical evidence in the 2012-2016 Buffeting Wars thread (w/ 2000+ posts) indicate it's both. "Fixes" include windshield, mirrors and winglets to block or modify flow over and along the side of the fairing.
@brock29609 is right, so I moved my post over to the Gen2 (2012-2016) Buffeting Thread, continuing comment to @Spec Please post followup comments over there.
Hi all,
Cheers
-I'm 6'2" in the morning and Peg lowering kits worked well for me on all my Stroms.
-some seats work for some people, others for other people. I never found a stock Strom seat to be comfy for me. On my first gen Strom Corbin Worked brilliantly, sort of okay on my 2012 DL650 and not very well on my 2015 DL1000. I have now found Russel Day long seat works brilliantly for me. expensive but seeing as I ride about 30,000 miles/ 50,000 km per year well worth the cost for me.
-By any chance does your current DL650 have "crash bars" and did your previous have them? Historically there have been lots of threads where those things seem to be the root of vibration at those revs.
-Don't know if the aero is the same on your 2019 vs my 2015 DL1000 but if so in my case a Madstad Bracket fixed any issue I have with buffeting. (I have since 2006 been using long stem mirrors on mirror extenders on my Stroms and Madstad has always made my Stroms buffeting free and allowed me to ride over 90 mph with my modular helmet open.
-I don't know if the Givi mounting bracket for your DL650 is the same as the DL1000, but on the DL 1000 the **metal** Givi rack includes some reinforcing bars that greatly strengthens the mount.
Hi all,
Cheers
there is something wrong with your strom.
I have a 19 and encounter zero vibrations whatsoever.
The seat softens up signifigantly after a few thousand KMS
Looks like yours was made on a Wednesday. Do you have crash bars fitted? If so have you ever tried to hold on to one of the crash bars as you ride through the rev range? Seriously interested.
My 17' vibrates thru the Givi crash bars and I'm going to do the foam thing this winter. Seat concepts, Madstad, and mirrors have cured the rest. This is our fourth V-strom and I love them, but spending $1500. to equip the bike so you can ride it as intended???
I have as well 2019 xt model and zero vibration at 0-7k rpm range been using so far.
Seat is comfortable for my arse but that personal, I know there are gel mods for seat.
Wind issues for me was easily resolved putting adjustable deflector for the stock windshield
and to tackle mirrors turbulence I need to replace them or put side wing deflectors.
Hi all,
Cheers
The good news is that you can address 3/4 of your issues with mods. I'm surprised you found the 650 rough... compared to my new 1000 the 650 was smooth as butter.
Hi all,
My 2009 DL650 seat was about as bad for me as my 2018. Hence the reason I ordered a Daylong as soon as I bought the bike.
I noticed this too on my 2018 DL650. At 9000 miles I replaced the stock tires with a Shinko 705 rear and an Anakee Adventure front. I mount and balance my own tires and I noticed that on the rear the amount of weight I needed to balance the the and wheel assembly did not change but the location moved about 30 degrees from where it was. On the front I needed to add a bit more weight and again it was off about 30 degrees.
None of this seemed odd to me, except for needing the same amount of weight on the rear tire, since I was replacing the tires. However, the bike was silky smooth at all speeds after I changed the tires and this leads me to believe that the factory did not properly balance the wheels.
For me I found that my 2018 DL650XT had far less buffeting with the stock screen than my 2009 DL650. I tried several different windscreens on both bikes and have settled down to a summer screen and a 3 Season screen. Overall I am more happy with the wind protection on my 2018 than my 2009. I am 6' tall with a 31" inseam.
I agree with you on that - on top of that they made it out of plastic. I also installed a Givi rear rack on mine as well
1 - 20 of 21 Posts
