An update and some further troubleshooting on the 04 Vee.
I made a new map for the PCFC. Between 1500 and 4000, and between 2% and 30% throttle, I've added a max of 7% more fuel. Contrary to what some would say, the bike now happily putts along above 3k rpm. I do not accelerate much at low RPM but cruising is fine. I'm getting about 40mpg 2up riding conservatively. Fueling seems nice now, and unexpectedly there is much less compression braking, although that could be because my idle is still a touch high, at 1400.
The last annoyance that I'm going to be chasing, once we can go outside without choking here in the PNW, is the 2500 to 3500 rattle while accelerating. This rattle only happens under low to moderate acceleration, like leaving a stop sign around town or shifting to a higher gear on a low speed limit road. The rattle sounds like someone shaking a bin half full of nuts. The frequency increases with the RPM, until at 3500 it suddenly goes away.
Here's what I know. This rattle did not happen on the test ride when it was running badly. The rattle was reduced quite a bit just before I found the rear plug fouled from the seafoam in the gas (see my earlier post about that). This leads me to think that the rattle only happens when the bike is running well. Btw, I've re-torqued all of the engine mount bolt and there are new cush rubbers in the rear wheel.
My theories are:
1: stronger or more defined power pulses are shaking something
2: the noise is from the straight cut gears on the clutch or in the transmission contacting, disengaging, and recontacting with the power pulses.
I'll run down the first theory, as there is nothing I can do about the second.
The rattle sounds like it is coming from a lower area on the bike. Sound is weird, and the apparent source of the noise can be misleading.
Chain? I have the slack set to 1.75" but the bike has a lowering link on it. I did not think about it before but the link may affect the chain slack requirement.
My swingarm is closer to being inline with the front sprocket than a stock bike. My chain may be way too loose, slapping around at those conditions.
Fairing? Large flat panels of ABS plastic might be acting like drumheads
Front sprocket? I'm running a sprocket without the rubber ring on it. None of my other bikes had the cush ring and I've not had this noise, but they were IL4s.
Something else? I've checked the exhaust gaskets, made sure that all the nuts and bolts on the whole bike are tight, and there are no missing plastic rivets on the plastics.
Is this normal? I would not expect so, I'd think that this noise would drive everyone batty.
Does anyone have suggestions? Thanks.
