1 - 4 of 4 Posts
I am having an issue with the decreased MPG on my '02 DL1000.
When I first go the bike (bought used last year) I was getting 40+MPG but now it is down to about 32-34 mpg for the same type of riding.
I have added some Caribou luggage, a Cee Bailey windshield and some electrical stuff. I also changed the gearing from 18-45 to 17-45. The gearing change has raised my rpm about 500 for the same speed. It used to be 4500= 75 mpg now it is 4500=70 mph.
I checked the vacuum balance and it is fine, checked the spark plugs and they are nice and clean. The air cleaner (K&N) is clean. The brakes do not drag and the bike handles fine.
I have no running issues with the exception of MPG. I have verifed the mileage with my GPS so there is not speedo error.
Any ideas?
Mike
Hi Mike,
I don't know where you are from, if you update your public profile, that would help.
What is the Ethanol content in your area?
A bunch of us have been witnessing the same issues recently. The bulk of my MPG drop was related to a problem in a TBS, after I was able to sync them, my MPG climbed back to just shy of where it should be (~ 39MPG vs 40 - 42 last year).
Any ideas?
Mike
Mike:
The answer is in your question. You are revving 500RPM more every minute, you have more drag from the luggage and windscreen etc. Anyway, check your tire pressure
The tire pressure is 42 on both ends of the bike.
We do have ethanol in the local fuel unless you run 91 octane. I may try the 91 just as a test.
Thanks for the tips.
Mike
1 - 4 of 4 Posts
