161 - 164 of 164 Posts
Discussion Starter #161
Sorry to hear about all the problems you've been having. The only problem I've had is the power thing. I ordered mine before they shipped so I have one of the early versions - no blue LED power cube, I'm afraid. But I did install a push on/push off button just in front of the seat release key which works pretty well. I will check to see if anything resets. When I changed the battery in the bike I didn't see any resets so I wouldn't think this one would. I am going to check the version of the firmware to see if it needs updating. Thanks for the tip.
For the camera mounting, I have my front camera mounted to the underside of the beak. I made a custom mount with some aluminum bar stock and it seems to be pretty good. It's not really Youtube quality, but it is good enough in case I need something for documentation or for insurance, which is what I bought it for. I posted pictures of the mounting at the beginning of this thread.
On the question of Blue tooth vs. WiFi, blue tooth 2.1 has a range of about 100m and blue tooth 5 has a range of about 400m and up to 1000m in the open field. Blue tooth 2.1 had a data throughput of up to 3 mbs which is more than adequate for video transmission. So, I think that I have to disagree and that I still would prefer to see a low power solution like blue tooth or perhaps a split option - Blue tooth for control and WiFi if you really need high bandwidth.
But, that's just a wish.
Cheers
Farkle Purchasing System
You can prefer Bluetooth all you want, but the fact is that BT just doesn't have the capacity to transmit HD video. 3.0 Mbit/s won't do it. Video over BT is technically possible (at a low resolution, quality, and framerate) but not worth doing. That is probably the main reason there isn't a single dashcam/action cam product that uses BT instead of WiFi.
I think I may have solved my mounting problem. I redeployed some of the rubber discs that came with the K2 kit. Windshield still vibrates a lot, especially at highway speeds. Can't fix that. But, camera is no longer rigidly mounted to the accessory shelf behind the windshield, which helps a lot.
That said, the rubber cushioning discs are falling apart. They have not dealt with exposure to the sun very well. I need to find rubber that stands up better, or else resign myself to replacing them every few months.
Confirmed, the power supply is yet again malfunctioning.
Over the last week, I've had the K2 both fail to power up when I turn on the bike, and turn off for no apparent reason while riding. Repeatedly. Not every time, which is the nature of the problem - it's intermittent.
The not-turning-on thing is new.
This is absolutely infuriating. I contacted the vendor, who promised to contact the manufacturer to figure out WTF to do.
Meanwhile, I think I found a workaround. It is possible to power the DVR through its micro USB power, found under the rubber flap next to the SD card slot.
I can power the system from the USB charger in my 12V socket, since the "proper" power supply is not reliable.
A drawback to this approach: the DVR cannot shut down as intended. It gets turned off suddenly So, the last 2 video clips being recorded are corrupted & unplayable.
No big deal. I can mostly work around that by using 1-minute clips. I typically don't need to record anything happening during the 1 minute before I turn the bike off.
Nope, that didn't work. There seems to be an overheating problem, which has become apparent with warmer weather.
On one ride, the K2 was extremely hot to the touch when I got home. I removed the SD card, and it was abnormally hot as well. The card doesn't work properly now. It either cannot be accessed, or will seem to work briefly but then not be recognized by the PC. It must have been damaged by the extreme overheating.
As to why the DVR would overheat: possibly a flaw in the v0.6x firmware branch. I've rolled back to v0.57 because that's what I had for the ~4 months when my K2 worked perfectly, in the winter and early spring.
Testing has not been possible this week because my front tire started falling apart. It is taking longer than it should to get a new one, so I'm not riding in the meantime. Running the K2 in my garage wouldn't really prove anything.
