1 - 19 of 19 Posts
Just got my July issue of MCN. Noticed in Downtime files, a letter from a guy who had an 04 DL650 which burned regular gas. He was disappointed that the MCN article reported the new 650 needed premium fuel. What followed was a lengthy discussion about the adverse effects of long term detonation on a motor.
Well, I've been burn 87 octane in my 2012 Wee since new, however, I thought I'd better go check the owners manual. Sure enough, it says 87 octane. Email sent to MCN. I'm sure they will get many corrections. BTW, as I recall, they also stated the wet weight as over 900 pounds.
MCN is great magazine, just do your own homework.
Yes,
I saw that too....
Thought they were probably wrong re: the fuel.
That lil' 650 will run on pee.
Also, the wet weight and GVW were obviously reversed.
They list
Wet Weight / 915
GVR / 516.5
I still subscribe and like the mag.
I called the editor once, Dave Searle,... got right through. Nice guy.
Everybody makes mistakes... everybody's feeling the pinch of our "recoved economy".
Dmilan
I noticed that too and was disappointed. So the manual does specify regular stuff after all. Good.
Regular here is 85.5 so I have to use at least midgrade if I want 87 or higher.
It's a small world. I read the same MCN Downtime Files section yesterday and promptly got my Owner's Manual out to double-check - sure enough, 87 required minimum. I'm surprised that they didn't catch it by doing a little research before responding to the question. Or maybe premium means different things to different folks? I also sent a friendly FYI e-mail to the editor about it.
The 87 or higher is for typical elevations. In higher elevations where 85 is sold, it works fine.
<<The 87 or higher is for typical elevations. In higher elevations where 85 is sold, it works fine.>>
Pat, that had always been my understanding until a few years ago when I bought a vehicle with a Ford Triton V-10 engine. In the engine owners manual it states that the recommended octane is 87, and then states that Ford does not believe in using a fuel with less than 87 octane at higher elevations. It's very specific about this.
Of course our V-stroms do not have Ford engines and my DL 650 owners manual isn't specific about this one way or another, simply stating "Your motorcycle required regular unleaded gasoline with a minimum pump octane rating of 87 ((R+M/2) method)." It does say regular but doesn't mention other than 87 octane, at least that I could find, so I find this quite confusing.
This is of particular importance to me because my home is at 5700 ft elevation and the town where I buy most of my gas is at 5280 ft (calls itself "the mile high town") and regular is 85 octane, mid-grade 87. Wanting to err on the side of caution, I've been explicitly following the Suzuki manual and using 87 but wondering if I'm wasting my money, which, being retired, I would rather not do.
Have you, or anyone else, perhaps discussed this issue with Suzuki for clarification?
Thanks for any further clarifying input. I need it! :eek:)
Mike
Idaho
www.rtwrider.net
If an engine doesn't ping, there is enough octane. I use 85 on trips in the mountains and it works fine.
Do Suzuki uses knock sensors? I know the BM F800GS / F650GS twin do, and get really economical fuel consumption figures, which when reading tests the L2 gets close to but is still about 10% worse than the BM.
I use 85 in the mountains and don't wonder even a little bit. Our bikes do not have knock sensors. If the fuel is too low in octane, the pinging will be heard rather than the timing changed to compensate.
My bikes tended to get better mpg at altitude using 85 in Colorado too. Gotta love the place!
Banned
my operators manual doesnt say that. but i have 05 DL1000 so maybe that why. or maybe youre just not reading it right. my manual says, "at least 87 or higher", or iow's, regular automotive grade fuel. which makes sense to me, see-n how suzuki is a UJM.
As I mentioned above, I sent an FYI e-mail to MCN about the premium vs 87 issue in their magazine. I got the following response...
"Thanks for writing us. You’ll see our response in the August Letters section of MCN."
Discussion Starter #18
I got an email from MCN acknowledging the mistake also. A correction will be in the August issue.
MCN is my favorite moto mag but they do get things wrong now and then. That's what happens when a mag includes actual technical topics rather than the useless garbage most of the others have in them.
1 - 19 of 19 Posts
