1 - 6 of 6 Posts
Hello,
I'm wondering if there's anything available to have a "back" extension on the shift lever?
I came over from the cruiser world and always enjoy being up to shift up by using the back of foot instead of having to tap up.
Can such a mod be used on a Storm? do they exist?
Nobody makes such an animal. There's no reason for it with footpegs, only with floorboards. The best place to make a change is between your ears unless you have a physical problem. There was somebody with ankle problems that had a machine shop weld a heel plate on the stock shifter.
Although you are crossing cultures in this concept, I can see value in it as upshifts can be difficult based on the footwear you prefer. I have some brand new Tourmaster boots still sitting in my garage that won't easily 'fit' in the space needed for shifting on my DL650A - a backbar added to the shift lever makes a modicum of sense.
I don't know the 650, but can't you adjust the shifter up a few degrees? Many m/c shifters are splined onto the shaft and can be rotated a little.
Both bikes can be moved on the spline for a coarse adjustment and have fine adjusters between the lever and the splined shaft. The rider can put the lever exactly where desired.
1 - 6 of 6 Posts
