1 - 20 of 23 Posts
My Anakee Wild rear tire lasted about 7000km's, very poor longevity, but it was used on a fair number of dirt/rock roads up the Dempster and then a lot of pavement on the way home. Still I would hope a tire to last closer to 12k.
The front Wild is fine, so I am keeping that. I was considering adding another Wild Rear just to see if it might last longer locally, but that seemed silly too, so I opted to try a Mitas E07 rear.
There are two models of this, the regular and the Dakar. The Dakar is listed as having a stiffer sidewall to make offroad riding better. I do like to ride offroad sometimes, and the difference in cost was only $10 so that is what I ordered.
I have it sitting here now and am surprised how stiff the sidewall actually is. On most tires I can compress the sidewall by hand, and that flexibility makes installing a tire easier by hand. This Dakar version is rock solid, it does not move at all by hand. I would never consider trying to install this with spoons.
I am wondering if this stiffness will transmit into a rougher ride? Has anyone tried both of these tires to compare?
I haven't tried the Anakee but I do run the Dakars. I am happy with the ride quality both on and off road. My rear is ready for replacement after just over 7000 miles.
I was actually curious about the two versions of the Mitas tire, the regular and the Dakar and how those compare.
http://advrider.com/index.php?threads/1237542/
http://advrider.com/index.php?threads/1229621/
Visited provinces:
Visited states:
I have used 2 sets of the standard Mitas E-07 but not the Dakar. The difference between them is that the Dakar has one more belt, four versus three if I remember correctly.
Acceptable but not outstanding on seal, good in the wet and fantastic on gravel etc. So much more stable and predictable on loose surfaces that a 90/10 tyre but like any tyre you wish to name a V-strom is never comfortable in deep sand or mud. I got 14,000 km from my first set and surprisingly the front was worn the worst. I ride seal to get to dirt roads.
How you ride affects tyre life so lots of hard throttle and hard braking will make a difference. Keep the pressures up as heat makes a tyre both more grippy and wear faster. Higher pressures will reduce the heat build up.
Bikeless 4 now
I just got an email that they are currently running a sale. The Mitas will definitely be my next tires.
I've said it before, I'll say t again in this thread
I won't be buying another set
Sorry buddy but you are well outnumbered on this one - in fact one of the very few not to like the E-07.
I don't find the any better on pavement tan a big block knobby, and not as good on gravel, I have no use for a chevron pattern tire, I do admit to their longevity though
IHMO, most of the raving is not admitting they bought a tire that is not so great, and going along with the crowd, comparing them to a sport touring tire for gravel road riding
oh, and they suck on wet
Discussion Starter #13
I got this tire installed today, the shop commented on how difficult it was to get on there, even with their machine. I thought that was kind of funny. Looking forward to testing it out.
I have mounted the non-Dakar version myself front and rear and had no issue with doing it with simple irons, so that seems strange. Echoing most of the sentiments, I find them incredibly competence-inspiring on gravel and I have had no issues with them in the wet (but I do not ride in the same conditions RandyO does) and I have run D606's and TKC80's on a KLR so have some experience with other more dirt-skewed rubber.
In 28,000km of riding I have gone through the OEM Trail Wings, then a original version Tourance on the rear and a E07 on the front and then, finally, changed out to the matched set with a E07 on the rear. Definitely a huge upgrade on the Tourance rear (which you would expect) on gravel roads (which is what I primarily ride on). Nice for us in Canada as one of the big importers (MX1Canada) is in the lower mainland of BC.
Where's the sale?
I've been reading your posts about the x300 on advrider and appreciate your perspective on most stuff. I have no doubt that a big block outperforms the E-07 off road, and that it may do as well on as the E-07 on road, leaving wear as the only advantage to the E-07.
I rode mine (E-07 Dakars) through a full day of rain in the Ozarks and didn't have any wet traction issues. I was particularly sensitive to that since the Heidenau K60's have a "slippery when wet" reputation.
I'm satisfied with the tire enough to buy another set.
Dislikes - passing out west at ~95mph I started to get bar wobbles. No bueno.
Grip in cornering is fine, but there is a distinct transition during corner lean that isn't there on a radial. That is, the radial is completely settled, but the E-07 feels like you had a passenger shift their weight slightly as you transition from upright to full lean. It is very consistent though. Other than that I can drag pegs in tight turns from 25-45 mph. Don't know upper limits.
Also, as another poster has already stated, the closest I've ever come to natural child birth was installing a set of Dakars by hand with tire spoons in my garage. Other than that, on/off road characteristics of the E-07 closely matches my performance expectations for the Strom as an "SUV" of motorcycles.
Keep posting about your x300, I'm thinking about one of those as a second bike.
Reactions: Motor7 and Brockie
...Also, as another poster has already stated, the closest I've ever come to natural child birth was installing a set of Dakars by hand with tire spoons in my garage. Other than that, on/off road characteristics of the E-07 closely matches my performance expectations for the Strom as an "SUV" of motorcycles....
Reading fail on my part as I failed to see that we were talking about mounting of the Dakar versions when I commented how comparatively easy I found hand mounting the regular version. The stiffer sidewall (obviously) would make a huge difference....
No not at all. I was referring to Bugzy's post right above yours where the tire shop had a hard time mounting his even with their machine. Didn't mean to disagree with you. I simply meant my experience was ... memorable.
I mounted mine in my garage with tools I carry on the bike to see if I could do it one handed in wilderness Alaska while fending off mosquitoes and wolves with the other hand.
Bikeless 4 now
Where's the sale?
I got an email from Mitas, not a dealer. Deleted it since I'm not in the market now. Running TKC 70 F&R on 1 and TKC70 F and Shinko 805 R on the other. Both configurations have been excellent. Sorry. Try Google?
Sent from my SM-N920V using Tapatalk
Will do. Thanks for the response.
1 - 20 of 23 Posts
