Strom Trooper banner
1 - 2 of 2 Posts
Farkle Purchasing System
Some thoughts on neckwear:
I bought one of these about 2 weeks ago. Having worn it for all riding since then, I wish I'd bought one when I started riding, last October. It's that good.
The Multi-Cool makes riding so, so much more comfortable. If you have ever found your riding jacket irritates your neck, or are looking for a way to stay somewhat cool in the desert, I don't think there is a better deal going.
This thing solved two problems at once.
One was that my Helite airbag vest was rubbing against my neck, especially when I turned my head, which got really really old on long trips. The vest material is stiff and a little rough, so it doesn't feel great on my neck and is a little distracting. With the Multi-Cool on, I can't even feel the vest touching my neck. All I feel is cool comfort.
Two was that I was getting ridiculously overheated in my gear. I haven't wanted to purchase a mesh riding jacket, both because it's not in the budget, and because I've read that air mesh is actually a terrible idea in the desert. As long as the Multi-Cool is wet, I stay much cooler than I would otherwise. It works a lot better than my previous solution - a soaked hand towel - because it stays in place much better, so that air is forced to pick up some moisture as it hits me.
It's true that my jacket, a Tourmaster Transition 4, has a zip-in neck cuff thing. While it is windproof and keeps the vest edges off my neck, the collar is stifling to wear in the heat, so I don't.
Columbia sells a similar neck gaiter, the Omni-Freeze Zero. I almost bought one of those, but the Multi-Cool is about half the price. Maybe the Omni-Freeze is better, I don't know.
If you wear an Omni-Freeze when riding, I'd like to hear from you.
In hot weather, the Multi-Cool's cooling effect is most welcome. I soak it and squeeze out excess per the instructions, before putting it on. Water wicks down into my T-shirt too, which is just fine as that provides yet more evaporative cooling.
It could be psychological, but I feel like having this cool, wet cloth around my neck as I ride helps cool down my core. I still feel the heat inside my jacket and overpants, but it's nowhere near as oppressive as when I used to ride without anything on my neck more than sunscreen. Or even a wet hand towel.
Not needing to wear sunscreen is great. It was always a pain in the ass. Not only did it feel greasy, even the expensive Neutrogena "dry-touch" stuff, but it would wear off after a few hours or I'd miss a spot, and get burned anyway.
Even when it's not hot out, such as in the morning on my way to work, I wear the Multi-Cool dry just to keep the vest off my neck & put a comfy layer between me and my jacket collar. Then the Multi-Cool sort of does a similar job to the silk scarves pilots used to wear.
This has definitely been one of my least expensive, yet most beneficial, gear purchases ever.
Years ago there were Neck Snakes. they had a gel pill in them that would swell up holding water. It worked kinda. I had one last from OKC to Tulsa and it was a dry as a popcorn fart by then.
Now I carry wet vests in a Wally World dry bag and change them every buncha miles and refresh the original as I go.
Keeping the Carotid Artery cool is what helps the head feel better.
I was lucky and got a BMW and Ducati wet vest for 10-20 bucks rather than the original too high price.
1 - 2 of 2 Posts
