1 - 10 of 10 Posts
Anyone have the Madstad bracket installed in the highest mounting position with the stock shield? This appears to be the best setting for me, however it looks as if the shield is flexing a lot during a ride and I am concerned this could cause the shield or the plastic at the base of the bracket to crack.
I think to be safe I will lower the bracket to the middle setting and order myself a Givi screen.
Just curious if anyone else has their Madstat installed at the highest setting and if it caused any problems - even the manual that came with the bracket does not recommend this position.
Cheers.
I have the Madstad mounted in the highest position on my '07 DL1000, with the windshield in the highest position about 75% of the time, and have had no issues.
I've had my Givi tall screen mounted at the highest Madstad position since day one (a year ago). There is some flex, esp at higher speeds, but overall it seems to work well.
The only problem I've had is that the Madstad allowed the shield to creep backward at higher speeds, no matter how tight the thumbscrews. I finally used four small bolts to firmly lock the shield in a position that I'm happy with.
In this regard I found the Madstad poorly designed.
Peter
I have mine all the way up, and forward. With the vent in there, I think it probably releases a lot of tension. But still... I am not worried about it...
That's odd. Even with a barn-door-sized V-Stream shield at the highest position I have not experienced that.
Bracket slipping
I experience the same condition mentioned ie. windscreen slipping backward. Finally installed those saw tooth edged lock washers that you frequently see on electrical connections. The windshield is the large Givi and it no longer moves.
Thanks for the tip, I too have had that problem. :thumbup:
1 - 10 of 10 Posts
