Last week i bought my first Vstrom, a 2007 DL650. I bought it used with about 20k miles on it. Was out riding the bike around (about 200 miles), then when i was climbing a hill the engine died. I still had power and the dash was on. Initially i tried to restart the engine, but to no avail. I can hear the starter, but the bike would not turn over.
When i got back home i started going through the threads to see the potential cause. Based on other posts i assumed it was a clogged filter. I tested this theory by removing the fuel line and trying to start the bike, no fuel came out. I installed a new pre-filter on the pump and put the tank back on my bike. With the fuel line off i tried to start the bike again but nothing.
At this point i decided to test the voltage of everything. I checked the fuses and all were good, checked the voltage at the battery pump relay and fuses and all were at 12v. When i checked the voltage at the fuel pump i was only getting 5v with the key on. Based on other post shouldn't i be getting 12v here?
What could be causing this drop in voltage? Im thinking the wire harness might be corroded some where. but really hope it is something simpler. Any suggestions will be greatly appreciated.
