That sounds more like something a throttle cable adjustment might help. You want as little slack in the push/pull cable setup as possible.
While the first gen DL 1000 did have fueling issues that most would work to fix, the second gen DL 1000 is much better. In fact I have not heard of a symptom like you describe. There can be a flat spot at low rpm, there is a Suzuki TSB out on that.
