1 - 3 of 3 Posts
Hi,
hoping someone can help. Both low beams not working, replaced bulbs, checked fuses, still not working. Could switch need to be replace, or should I check bulb plugs? Thanks for any help from East Coast of Canada (Newfoundand and Labrador)
Check the yellow plug that is attached to the back of the radiator shroud. When my low beam stopped working I found I had corrosion on the terminals of that plug. You may have to remove the left side body panel to gain decent access.
Discussion Starter · #3 ·
Thanks for the wiring check tip
I'll certainly check the left side yellow connector, very much appreciated. Thanks again
Ian
1 - 3 of 3 Posts
