1 - 20 of 35 Posts
Recently a buddy picked up a KLR 650 so I am looking to ride with him off road. Obviously I know his KLR is a better off road machine but I want to try to hold my own. In addition, my son has a 50 and wants to start trail riding. Here is how my bike will be used: commuting 3 to 5 days out of the week (30 miles a day at hwy speeds)and I will be trail riding with him on the weekends. I live in NE Florida so most of the off road terrain is sand/dirt/mud. There are no rocks to contend with. What tires have you had experience with that you would recommend for my application
Metzler Karoo 3
Continental TKC80
Heidenau K60
Mitas E-07
Shinko 804/805 Big Blocks
I tend to buy my tires locally rather than online since my dealer will install the tires for free if you buy it from them. However they don't carry The Heidenau or the Mitas. They are available online though. Again, I am hoping to hear from personal experience if possible
Go with the Shinko 804/805 for your riding applications..........IMHO.
Any particular reason why you like them for my application?
Also would there be any issues with the tire blocks hitting my front fender?
E7s will give you wet traction and okay off pavement ..what I run on my KLR650 in tropical Australia.
K60s better mileage but might be slippy on wet pavement ...not such a big issue with ABS
I switched from the 606s on the KLR and tho I like the K60s on my Wee I decided the extra mileage was not justified in Australia.
This is a heavy bike for mud and sand and no 50/50 tire will help a whole lot tho will be way more stable on dirt and gravel and tracking our of rain gutters etc.
Dunlop 606s would be better but not sure how much life you will get with your commuting - they will give you far better control in mud and sand.
https://www.revzilla.com/product/dunlop-d606-dual-sport-tires
You could probably snag a more dirt oriented bike pretty cheaply .. lighter, better clearance etc....even a KLR ...
https://www.cycletrader.com/dealers/Top-Gear-Inc.-2921914/listing/2000-Kawasaki-KLR650-120038740
Reactions: SECoda and Spec
That's the ultimate goal. However I don't have the disposable income for a second bike at this time. The $200-$300 for some 50/50 tires is a lot more doable than $2000-$3000 for a whole bike at the moment
I rode Osceola National Forest on some Bridgestone Trail Wings and did OK till I hit some mud, in which case the front end just washed out. Where I will be riding will be very similar to there. To get an idea of the terrain, please check out this thread of that ride http://www.stromtrooper.com/general-v-strom-discussion/308130-laugh-my-pain.html
Hopefully that helps explain the terrain I will be tackling
A bit better for sand/silt than the E07 or K60.....
I can only reference the Heidenau K-60.
It was the only tire available to me last year as I was crossing Canada from Vancouver Island. I needed tires by the time I made Winnipeg and a call out to numerous shops failed to find any tires in stock that fit the bike. Reaching out to a BMW dealer he had one set of tires that did fit and they were in stock. I had no choice so I got over the sticker shock and put them on. They were no harder to install than any other tire I have done.
I proceeded on my trip east to Newfoundland and with a fully loaded bike I started doing side trips up dirt mining roads, into fields to seek out views, dirt roads to unknown places etc. I absolutely trust these tires, dry or wet. With nothing on the bike aka 'naked', it corners so well my boots are always touching the pavement. Tar snakes have disappeared! I have not done true 'sand' in depth so cannot comment there but they were great in wet gravel/dirt but a bit slick in wet clay. They have 13,000km's on them now and they have worn to where they have erased those small cutouts on the outer tread. Probably another 13k left to go where I will be replacing them with the same.
My only negative comment is that the front tire does hum but 'oh well' :)
I added a tooth on the rear sprocket (48T) and got this Avon AV85 TrekRider on the wheel (spocket weights don't work since the spokes are in a reverse orientation on the 650XT - weights fall to the wheel hub). I'll get the wheel on the bike tomorrow. The Avon AV54 TrailRider sitting there only lasted 6500 miles (fun-filled) and wouldn't pass the state vehicle safety inspection due by end of June.
Raining this week. Full report later.
BTW: #1, the Avon AV53 TrailRider front is still in good condition, so I'll continue to use it. #2, I used balancing beads in the AV53 and you can see how it polished the tire's inside. #3, the center section of the Avon AV53 is very flexible and gave a good ride although shorter than I had hoped. There was very little variation in tread depth down the middle, so I'm assuming that the balancing beads either corrected the imbalance or did no harm to an already balanced tire.
Hard to really go wrong with any of the tires the OP listed and probably and advantages/disadvantages will be marginal and/or even out when split between your two applications. That being said, I'd do one of 2 things... go with the Mitas E07's or blow your buddy's mind and buy a brand new KLR.
Rather than spending $300 on a set of tires for the V1, I'd suggest saving up for a little bit and spending $1000 on a 90's DR350.
For 50/50 tires add the Michelin Anakee Wild. Delete the Heidenau and Mitas (fine tires, but aren't 50/50, whatever that means, and add TKC70 to this group). Avon Trek Rider is more than 80/20 and less than 50/50. Maybe in the same category as the Heidenau and Mitas, and maybe knobbier.
For your 30 mile highway commute, you want the K60/E-07/TKC70/Trek Rider.
We could have this discussion all day. Yes, a dedicated off road would be better. But
1) I need tires anyway. They are worn so it's an expense I have to make regardless
2) it's an adventure bike, may as well "adventure" with it
3) I don't want to wait 6 months to a year to buy a second bike to ride with my friend and my son
Sent from my SM-G950U using Tapatalk
Reactions: kd70qc
Discussion Starter #13
I looked at the Anakee Wild but the reviews I saw weren't very good.
The E07 is a 50/50 rated tire, and trust me there aren't many.......especially which work nearly as good and last as long. Reviews for the TKC70 are all over the place, but just do some research on the E07 reviews and report back. ;)
I ride E07 Dakars (tougher sidewall is a must in Utah if you're going to be riding over rocks). I honestly do most of my miles around town. The E07 is a fine road tire--been up to 85 mph on it now and it's stable (complaints about the Heidenau 50/50 tires are that they are unstable at high speeds). I have on rare occasions noticed a little wiggliness in the rear on surface street corners if I'm maybe a bit too fast. They tend to wander a bit on grooved cement freeways, but some time in the dirt will help you feel confident in spite of that. Summary: on-road performance with the E07's is a compromise per an 80/20 tire, but so far it hasn't impacted me at all. I don't try to drag my knees anywhere...
Off-road, this tire was (for me) like discovering fire! I've ridden shallow sand, gravel, and baby heads and it's held up great. In about 4 weeks I can say more about sand washes (Fathers Day weekend trip to Moab), but for what I've done so far, I'm happy. Other then the sand washes (and no tire is going to help here, the Strom is just way heavy), I'm totally confident about our plans to ride Potash Rd, Schafer Rd, and Lathrop Canyon.
Every time I ride the Strom off-road now, two things happen: 1) I wonder how much easier it'd be with a true dual-sport bike (been eyeing DRZ's for a while now), and 2) I smile a ton, and dream of longer rides in spite of the Yellow Pig's high center of gravity and my total lack of off-road skills.
news to me
that was my reaction when I put Dunlop 606s on my KLR.. like wow ...it goes exactly where pointed and climbs out of rain gutters effortlessly.
I have since switched to E07s for thebetter road manners but when you get some real traction it is an eye opener.
I'm also considering something light in Australia - Maybe BMW310 ( not off road but okay for forest trails )
Ah yes.....Shinko big blocks, yummy yummy on and off pavement tires and they look bad ass!!!!
Love my E-07's. Very effective on marginal dirt roads/tracks and adequate on seal as well. I swapped from Karoo 3's as they wore too fast (but were a scratchers dream). Both are head and shoulders better everywhere than the OEM Bridgestones.
BTW the BMW310GS is not available here yet. How about a Versys X-300? Cheap as chips and probably more reliable than a BMW.
I'd dream of going on one of those BMW Safaris on a 310GS and tackling those loose uphill tracks that end up as parking lots for horizontal beached whales. >:)
Discussion Starter #20
Decided the break in the Shinkos by spending some time with my son over the weekend. I am really amazed at how well these handle the soft sand we were in! A bike this heavy shouldn't feel that controlled on a surface so soft. So far loving the tires.
Also highway speed (70-80mph) is surprisingly comfortable. I honestly thought I'd hear or feel the tires more but I forgot I had them on.
1 - 20 of 35 Posts
