I say that as long as the normal maintenance has been kept up you should be good to go. But I would:
Clean and Lube the chain
Change the Oil and filter
Check coolant level
Check brake and clutch fluid level
Check tire pressure
Check to make sure all the scews and bolts are tight
Make sure you get all the stuff done a week or so before you leave in case you find something that needs to be replaced or something just goes wrong.
Hope this helps.
Check coolant level
Check tire pressure
Hope this helps.
