1 - 6 of 6 Posts
Just last week installed handguards on my Wee. Yesterday found a small ice patch resulting in a low speed drop. Obviously took out the stock turn signal and bent the hell out of the bar end, Givi engine guards saved everything else.
Research leads me to believe Suzuki does not sell the long bolt used in the kit only the short stock bolt.
Has anyone found a good aftermarket source for the bolt? I believe its a M6 x 140mm
Normally, it can be straightened. If not, the Glee kit eliminates the in handlebar spacer and uses a shorter screw with only the rubber expander along with the nut containing it inside the handlebar. Try that.
1 - 6 of 6 Posts
