1 - 17 of 17 Posts
I will be replacing the stator on a 2003 Honda Shadow, and the manual calls for a liquid gasket sealant instead of a rubber gasket.
Can anyone recommend brand names of this stuff so I know what to buy? I'm in Canada, but Canadian Tire sells lotsa stuff from the states, so I can probably get the same brands as you guys south of the border.
Yes, I know. I'll put the bong away until -after- the stator is installed...
Janice, Permatex Black gasket sealant...on the shelf at Canadian Tire :) ... follow the instructions on the package and you shouldn't have any issues :) Craig
Liquid Gasket...
I have used ThreeBond Silicone Liquid Gasket 1211, Part Number TB-1211. It's expensive stuff at $25.00 USD for a 3.5 oz tube, but it's the good stuff. Has worked great on our bikes.
Whatever you use, be very careful and don't let big gobs of it get on the inside perimeter of the case or cover. You don't want pieces of the solidified sealant breaking loose and getting into your engine, where it can clog oil passages, and get between gear teeth, etc.
suzuki bond used to be wicked. worked on lots of stuff. not even sure they still make it.
And the winner is:
Just because I'm lazy and cheap. There's a Canuck Buck right down the street.
Thanks everyone.
Amazon.com: Three Bond Liquid Gasket 1194 TB1194: Automotive
Do NOT trust silicone in continuous hot oil applications
The stator side of the case is not oil filled. There may be a teensy bit of oil that has seeped past the crankshaft seal, but that's about it. So I'm not too worried about lots of hot oil.
The clutch side would be an entirely different matter, as it's full of hot oil all the time.
Thanks for the feedback everyone, and have a happy bong-filled day. :beatnik:
Janice, just to beat it into you again, just a film on both surfaces is your friend. Too much, and NOT your friend. Even if it is not part of the crankcase you don't want globs of that stuff floating around. A film will seal just as good as a bead in this case.
I'm with you, rich
Do NOT trust silicone in continuous hot oil applications[/QUOTE]
Despite what we read on the internet. :green_lol:
I like blue permatex however it is not the same as what the factory uses
I do use it in addition to a gasket but not alone without one.
The threebond or Yamaha 4 is the proper metal to metal material like case splitting
I will live in my Idaho you live in yours
I am curious to know where you take this information, because at least 2 automobile manufacturer use RTV silicon as OEM oil pan or valve cover gasket.
Don't expect an answer that makes any sense from richw. I used black Permatex silicone on a Corvette's weeping oil pan drain plug and had absolutely no problem even with the 'Vette's notoriously high engine temperatures.
Discussion Starter #16
Even a blind pig finds an acorn now and again
More high precision automotive repair
Blind pigs? Acorns?
WTF?
Dude, put down the bong. :beatnik:
Blind pigs? Acorns? WTF? Dude, put down the bong.
richw doesn't need any chemical stimulus, Janice. If you follow his posts faithfully you will discover that he is channeling subspace communications from planet Zergon.
Sadly the translation program he uses is often not adequate to render these messages into any known human language or logical form.:mrgreen:
1 - 17 of 17 Posts
