Is it possible to wire a supplimental LED brake light bar into the existing brake light wire? Does it require more electronics than that?:confused:
sure is. Just splice or connect the aux wire to the existing brake wire.
That's how I connected the LED brake light on the Kappa top box.
If your LED light is just a supplemental light, there's no need of using diodes or anything like that. Depending on your LED light setup, you might need to connect the + to + and - to - , otherwise it wouldn't work. Some LED light setups have some more electronics involved inside, and It wouldn't matter if you mix the wires, it would still work. But, maybe that's too much info already!
Thanks for the replies. I was just about to order a led light bar to mount in addition to the factory brake light, when I read. (Logic circuit required) sold separately.:yesnod:
Check out Hyperlites. They come with all the fixin's and work very well.
