Key on - Panel does not light up and does not start
1941 Views 8 Replies 8 Participants Last post by  AZ081000
3
V-Strom DL650 e DL650A 2011
The bike was in the garage, I went to start it and the panel doesn't light up and the bike doesn't even start.
It doesn't turn on the headlight, it doesn't inject the gas pump, it doesn't work, it flashes, it doesn't turn on the taillight and it doesn't horn.
The only thing that works is the neutral light on the dashboard.
  • The battery is new, marks 12.32V, everything is fine.
  • I checked the ignition key, everything is fine.
  • I checked the fuse box, everything is fine. All are at the correct voltage.
  • All terminals have been disconnected and cleaned.
Motorcycle lovers, what could it be?
See less See more
1 - 9 of 9 Posts
Did you also check the 30A main fuse?
Reactions: 1
I tested all the fuses and their amperages and they are normal!
!2.3 at the battery is a little low
I would bridge the bolts on the starter solenoid with a spanner, you should get some sparks and the motor should crank.
If this does not happen it is your battery or the battery connections, (they work loose on bikes) also check the earth cable connection at the motor
If the motor cranks look at the big plug under the rubber cover on the left side above the radiator, look for hot/ burnt connections
Reactions: 1
Battery should be 12.7-12.8V
Reactions: 1
I would confirm the large multi-pin connector leading to the dash is OK. Pull it apart and check the condition of the pins. Look for evidence of heat and/or loose pins. Interesting that the Neutral light works and nothing else. Interesting that the Ignition switch is out. I've had more show on my 2011 when the Stator went out, the battery died, and the voltage was well under the 12.32 stated.
I'm with @Rick505. Since the display does not light up with anything, I'd start with the big connector under the black rubber/plastic cover on the front left side.
Rectangle Font Art Pattern Diagram
See less See more
I still suspect the main fuse. I had exactly those symptoms with a blown main fuse.
Why is the ignition switch out? Did you replace the ignition switch with an aftermarket one? If so, then possible the wires do not match-up, or the ignition switch connector is not fully mated.
Several things to look at.
Reactions: 2
1 - 9 of 9 Posts
